    Tetris For Tab5
    PROJECTS
      shmusica
      Tetris Game For TAB5
      Quick Operation Table
      What to Do How to Do It
      ⬅️ Move Left Swipe left on the screen
      ➡️ Move Right Swipe right on the screen
      🔄 Rotate Piece Tap/Click on the screen
      ⬇️ Hard Drop Swipe down on the screen
      🎵 Sound Effects Automatically plays when moving, clearing lines, or pieces land
      Interface Guide
      Location What's There What It Does
      Top-Left Score Display Shows current score
      Top-Center Level Display Shows current level (increases as you clear lines)
      Top-Right Lines Display Shows total lines cleared
      Middle Game Board Main playing area (10x20 grid)
      Middle Current Piece The falling tetromino you control
      Middle Ghost Piece Shows where the piece will land (semi-transparent)
      Middle Next Piece Preview Shows the next piece coming
      Game Rules
      ✅ Objective: Fill complete horizontal lines to clear them and score points
      ✅ Scoring:
      • Single line: 100 points × level
      • Double lines: 300 points × level
      • Triple lines: 500 points × level
      • Tetris (4 lines): 800 points × level
      ✅ Level Up: Every 10 lines cleared increases the level (faster falling speed)
      ✅ Game Over: Game ends when new pieces can't spawn at the top
      Important Tips
      ✅ Single Block Movement: Each left/right swipe moves the piece exactly 1 block
      ✅ Hard Drop: Swipe down to instantly drop the piece to the bottom
      ✅ Rotation: Tap anywhere on the screen to rotate the current piece
      ✅ Sound Effects:
      • Move sound when rotating pieces
      • Clear sound when lines are cleared
      • Hit sound when pieces land
      ✅ Auto Fall: Pieces automatically fall down at increasing speed as level increases
      ✅ Ghost Piece: Semi-transparent preview shows where the piece will land
      ✅ Next Piece Preview: Always shows what piece is coming next
      Controls Summary
      Gesture Action Notes
      ← Swipe Left Move left 1 block Can swipe continuously while holding
      → Swipe Right Move right 1 block Can swipe continuously while holding
      ↓ Swipe Down Hard drop to bottom Instantly drops piece
      Tap/Click Rotate piece Rotates 90° clockwise
      Download & Burn the Firmware from M5Burner:
      Device Type: Tab5
      Search: Tetris For M5Stack Tab5
      It's that simple! Enjoy your classic Tetris game! 🎮
        shmusica
        Touch & M5 Stick2 module is also support!
        plug M5 Stick2 module into Port.A
        And have fun with you Stick2 Module Control!
