    AtomS3R M12 camera sync lines and image quality issue with esphome
    atoms3rcameraatomesphomehome assistant
    2 Posts 1 Posters 428 Views 1 Watching
      shaulliv
      I'm trying to install esphome and I'm experiencing very poor camera image quality (the horizontal line is scanning from top to bottom and the vertical lines seems to be sync lines).capture (3).jpg
      The demo application that came with the device had much better image quality, so I'm reasonably sure it's not the hardware.
      Here's my yaml config, it's based on the official example (https://docs.m5stack.com/en/homeassistant/camera/atoms3r_m12):
      esphome:
        friendly_name: M5Stack AtomS3R M12
        on_boot:
          priority: 800
          then:
            - lambda: |-
                gpio_set_direction(GPIO_NUM_18, GPIO_MODE_OUTPUT);
                gpio_set_level(GPIO_NUM_18, 0);
                vTaskDelay(pdMS_TO_TICKS(1500));
      esp32:
        variant: esp32s3
        framework:
          type: esp-idf
      # Enable logging
      logger:
        level: DEBUG
      # Enable Home Assistant API
      api:
        encryption:
          key: "42....0="
      ota:
        - platform: esphome
          password: "T.....t"
      wifi:
        ssid: secret_ssid
        password: secret_password
        # Enable fallback hotspot (captive portal) in case wifi connection fails
        ap:
          ssid: "Camera Fallback Hotspot"
          password: "sRgT7413"
      external_components:
        - source: github://DennisGaida/m5stack-atoms3r-components@main
          components: [bmi270_bmm150]
      captive_portal:
      web_server:
        port: 80
      psram:
        mode: octal
        speed: 80MHz
      i2c:
        - id: BMi270
          sda: GPIO45
          scl: GPIO0
        - id: camera_i2c
          sda: GPIO12
          scl: GPIO9
          frequency: 100kHz
          timeout: 10ms
          scan: true
      sensor:
        - platform: bmi270_bmm150
          i2c_id: BMi270
          address: 0x68
          update_interval: 5s
          acceleration_x:
            name: "BMI270 Accel X"
          acceleration_y:
            name: "BMI270 Accel Y"
          acceleration_z:
            name: "BMI270 Accel z"
          gyroscope_x:
            name: "BMI270 Gyro X"
          gyroscope_y:
            name: "BMI270 Gyro Y"
          gyroscope_z:
            name: "BMI270 Gyro z"
          temperature:
            name: "BMI270 Temperature"
        - platform: wifi_signal
          update_interval: 60s
          unit_of_measurement: "dBm"
          accuracy_decimals: 0
      text_sensor:
        - platform: wifi_info
          ip_address:
          ssid:
          mac_address:
      button:
        - platform: restart
      esp32_camera:
        external_clock:
          pin: GPIO21
          frequency: 20MHz
        i2c_id: camera_i2c
        data_pins: [GPIO3, GPIO42, GPIO46, GPIO48, GPIO4, GPIO17, GPIO11, GPIO13]
        vsync_pin: GPIO10
        href_pin: GPIO14
        pixel_clock_pin: GPIO40
        resolution: 640x480
        jpeg_quality: 15
        test_pattern: True
      esp32_camera_web_server:
        - port: 8080
          mode: stream
        - port: 8081
          mode: snapshot
      Here's an extract from the build log with issues:
      Hard resetting via RTS pin...
      INFO Successfully uploaded program.
      INFO Starting log output from /dev/ttyACM0 with baud rate 115200
      [13:37:49.066]e:123]: Unsuccessful boot attempts: 0
      [13:37:49.066][D][esp32.preferences:153]: Writing 1 items: 0 cached, 1 written, 0 failed
      [13:37:49.066][I][app:091]: Running through setup()
      [13:37:49.066][I][i2c.idf:206]: Performing bus recovery
      [13:37:49.074][I][i2c.idf:206]: Performing bus recovery
      [13:37:49.075][E][i2c.idf:243]: Recovery failed: SCL is held LOW on the bus
      [13:38:00.278][C][component:278]: Setup i2c took 11203ms
      [13:38:01.778][C][component:278]: Setup esphome.coroutine took 1499ms
      [13:38:01.780][C][bmi270_bmm150:483]: Setting up BMI270 ...
      [13:38:01.782][D][bmi270_bmm150:491]: Soft reset...
      [13:38:01.785][D][text_sensor:113]: 'MAC Address' >> 'B4:3A:45:BE:18:4C'
      [13:38:02.167][C][component:278]: Setup esp32_camera took 380ms
      [13:38:02.177][C][wifi:610]: Starting
      [13:38:02.231][D][wifi:1263]: Starting scan
      [13:38:02.233][C][component:278]: Setup wifi took 65ms
      [13:38:02.240][W][component:422]: api set Warning flag: unspecified
      [13:38:02.245][I][app:138]: setup() finished successfully!
      [13:38:03.794][C][i2c.idf:093]: I2C Bus:
      [13:38:03.794][C][i2c.idf:094]:   SDA Pin: GPIO12
      [13:38:03.794][C][i2c.idf:094]:   SCL Pin: GPIO9
      [13:38:03.794][C][i2c.idf:094]:   Frequency: 100000 Hz
      [13:38:03.794][C][i2c.idf:100]:   Timeout: 10000us
      [13:38:03.798][C][i2c.idf:107]:   Recovery: failed, SCL is held low on the bus
      [13:38:03.798][C][i2c.idf:114]: Results from bus scan:
      [13:38:03.798][C][i2c.idf:116]: Found no devices
      [13:38:03.813][C][psram:016]: PSRAM:
      [13:38:03.814][C][psram:019]:   Available: YES
      [13:38:03.815][C][psram:021]:   Size: 8192 KB
      Things I already tried:
      • Changing up and down clock frequencies
      • activating/deactivating aec/agc, changing aec/agc settings
      • changing brightness
      • Messing around with the lambda (this got rid of the "Recovery: failed, SCL is held low" but the camera issue remains):
                // 1. Enable I2C/Sensor Power (GPIO18 LOW)
                // 2. Hardware Reset the Camera (GPIO38)
                // The sensor needs a LOW pulse to reset properly.
                gpio_set_direction(GPIO_NUM_38, GPIO_MODE_OUTPUT);
                gpio_set_level(GPIO_NUM_38, 0); // Reset active
                vTaskDelay(pdMS_TO_TICKS(100));
                gpio_set_level(GPIO_NUM_38, 1); // Reset released
                // 3. Give the hardware time to stabilize after power-up
                vTaskDelay(pdMS_TO_TICKS(1000));
      • Disabling sensors
      Any help in fixing the issue would be appreciated.
        shaulliv @shaulliv
        @shaulliv
        I also tried changing the following settings:
          frame_buffer_count: 2
          frame_buffer_location: dram
        and
        priority: 1000
        lowered resolution to 320X240.
        and
        External_Clock frequency: 8MHz
        All without success.
