    [M5TAB5]Display flicker issue. Is this a manufacturing defect?
    2 Posts 1 Posters 414 Views
    • Y Offline
      y-shibata-aqua-k
      Device: M5Tab5
      Condition: Brand new (Out of the box)
      SN: K14525120100251
      Environment: Windows 11 / Arduino IDE 2.3.2 & 2.3.8
      Board Manager & Libraries: Latest versions
      USB Cable: Tested with 2 different cables
      Battery Level: 98%
      Tested Sketches: M5GFX -> BASIC -> BarGraph, along with custom printf and sprite drawing samples generated by Gemini.
      Hello everyone,
      I uploaded a sample sketch to my M5Tab referencing the official M5Docs, but I am experiencing an irregular screen flickering issue, as you can see in the below video.
      https://youtu.be/X8-WdUFt3Ag
      This symptom persists even if I change the drawing methods (such as using sprites vs. direct drawing) or alter the update timing for the text and background.
      Has anyone experienced this exact same issue and successfully solved it?
      Or is it highly likely that this is a hardware defect with my specific M5Tab unit?
      Any advice or insights would be greatly appreciated. Thank you.
      • Y Offline
        y-shibata-aqua-k @y-shibata-aqua-k
        @y-shibata-aqua-k
        I was able to resolve this issue by updating the M5GFX library in the Arduino IDE to the latest develop branch version.
        Therefore, I will close this issue.
