    Unit Roller485 - ease in out in position mode?
    1 Posts 1 Posters 240 Views
    • B Offline
      bontempos
      This is the closest I got on a code which provides some sort of acceleration/deaceleration on jumping btw positions. I wonder if is there an official way to achieve this smoothly. Thanks
      #include "unit_rolleri2c.hpp"
      #include <M5Unified.h>
      Going to random position every 1 second - trying to move with ease in/out, but very artificial/jittery - not smooth.
      UnitRollerI2C RollerI2C;
      const int32_t UNITS_PER_DEGREE   = 100;
      const int32_t POSITION_TOLERANCE = 150;   // ~1.5° arrival threshold
      const uint32_t MOVE_DURATION_MS  = 3000;  // total time per move (ms) — tune 1000–5000
      const uint32_t STEP_MS           = 40;    // trajectory update interval (ms)
      const uint32_t PAUSE_MS          = 1000;  // pause at target before next move
      int32_t basePosition = 0;
      // ── Ease-in / ease-out using a sine curve ──────────────────────────────────
      // t=0.0 → 0.0  |  t=0.5 → 0.5  |  t=1.0 → 1.0
      // Accelerates from rest, decelerates to rest — smooth S-curve.
      float easeInOut(float t) {
          return (1.0f - cosf(t * PI)) / 2.0f;
      // Drives from startUnits → targetUnits over MOVE_DURATION_MS with ease in/out.
      // Returns true when the motor confirms arrival within tolerance.
      bool easedMoveTo(int32_t startUnits, int32_t targetUnits) {
          uint32_t moveStart = millis();
          while (true) {
              uint32_t elapsed = millis() - moveStart;
              float t = min((float)elapsed / (float)MOVE_DURATION_MS, 1.0f);
              // Compute eased intermediate setpoint
              float   eased        = easeInOut(t);
              int32_t intermediate = startUnits + (int32_t)((targetUnits - startUnits) * eased);
              RollerI2C.setPos(intermediate);
              // Once we've sent the final setpoint, check arrival
              if (t >= 1.0f) {
                  int32_t actual = RollerI2C.getPosReadback();
                  if (abs(targetUnits - actual) <= POSITION_TOLERANCE) {
                      return true;  // ✅ arrived
                  // Give a small extra window for the PID to settle
                  if (elapsed > MOVE_DURATION_MS + 1000) {
                      return false; // ⏱️ timed out even after easing finished
              delay(STEP_MS);
      int32_t degreesToUnits(float deg) { return (int32_t)(deg * UNITS_PER_DEGREE); }
      float   unitsToDegrees(int32_t u)  { return u / (float)UNITS_PER_DEGREE; }
          Serial.begin(115200);
          delay(500);
          randomSeed(analogRead(0));
          bool found = RollerI2C.begin(&Wire, 0x64, 2, 1, 400000);
          if (!found) {
              Serial.println("❌ Roller485 NOT found on I2C! Check wiring.");
              while (true) delay(1000);
          Serial.println("✅ Roller485 found!");
          Serial.print("Vin (x0.01V): "); Serial.println(RollerI2C.getVin());
          Serial.print("ErrorCode: ");    Serial.println(RollerI2C.getErrorCode());
          RollerI2C.setOutput(0);
          RollerI2C.setMode(ROLLER_MODE_POSITION);
          RollerI2C.setPosMaxCurrent(80000);
          RollerI2C.setOutput(1);
          delay(100);
          basePosition = RollerI2C.getPosReadback();
          Serial.print("Base position (raw): "); Serial.println(basePosition);
          Serial.println("Ready. Starting eased random position loop...\n");
          delay(500);
      int32_t currentTarget = 0; // tracks last target so we ease FROM it
          // Random angle offset from base: -180° to +180°
          float   targetDegrees = random(-180, 181);
          int32_t targetUnits   = basePosition + degreesToUnits(targetDegrees);
          int32_t fromUnits     = RollerI2C.getPosReadback(); // start from actual current pos
          Serial.print("➡️  ");
          Serial.print(unitsToDegrees(fromUnits - basePosition), 1);
          Serial.print("°  →  ");
          Serial.print(targetDegrees, 1);
          Serial.println("°  (easing...)");
          bool arrived = easedMoveTo(fromUnits, targetUnits);
          float actualDeg = unitsToDegrees(RollerI2C.getPosReadback() - basePosition);
          if (arrived) {
              Serial.print("✅ Arrived at ");
          } else {
              Serial.print("⏱️  Stopped at ");
          Serial.print(actualDeg, 1);
          Serial.println("°");
          Serial.print("   ErrorCode: "); Serial.println(RollerI2C.getErrorCode());
          Serial.println();
          delay(PAUSE_MS); // pause 1 second at target
