Neopixel units not working in uiflow 1.2
I have tried multiple M5stacks and also different ports but the neopixels don't appear to be working in UIflow no matter what I am trying. They work just fine if I jump over to Arduino and program them there but they no longer look to be working in the latest Uiflow. I am not getting an error I am just not getting any light from the neopixels. The units neopixel library was working on previous versions but I think it might be broken. Can somebody please verify this.
I will take a look tonight. Normally they run on Port A, I will check when I get back to the bench.
Conformed, no response to Neopixels on M5Core
Recommend to use FastLED library instead of neopixel library
@watson said in Neopixel units not working in uiflow 1.2:
how do you use fast led in UIFLOW
Noted, thanks for the heads up guys, and my apologies. I will inform the team and we'll get it sorted asap. @watson they are talking about no neopixel control in uiflow not in arduino
Neopixel hex not working with M5Stick on Firmware 1.2.2 in UIFLOW!
Hello @ajb2k3 Do you mean this unit?
@watson
Yes the Hex, was working fine before the 1.2 update.
@ajb2k3 Have you connected HEX with the input direction?
As I said before, it was all working pre 1.2 via port A the i2c port.
@ajb2k3 As a software engineer told, version 1.2.2 has fixed this bug. You can try it.
Works with M5STACK
Does not work with M5STICK!
@ajb2k3 Does you keep M5Stick be lastest vesrion (v1.2.2) ?
@watson Yes,
