    SOFTWARE
    7
    69
    399.5k
    • G
      GACHAPO
      For the MK1 (no case) use cam0.02
      This is my camera;
      I have UIFLow-v 1.2.3-en loaded and I have setup an IP address but nothing is loading.
      The options I have are on the image I loaded - I see no cam0.02?
        ajb2k3 @GACHAPO
        @gachapo There should be an option in the top dropdown box to select it.
        alt text
        Click on the box next to firmware
          Click on the M5Flow-v1.2.1-en and a box will drop down, scroll through the list and the cam firmware is near the top.
          • G
            GACHAPO
            That's my point - there's nothing more than the image I sent.
            The only choices I have are on the left and the only drop down boxes are at the top and relate to the COM port and Baud rate??
              ajb2k3 @GACHAPO
              @gachapo said in M5 Burner Firmware Option Update:
              Sorry No image has appeared.
              • G
                GACHAPO
                  ajb2k3 @GACHAPO
                  Um, something is not quite correct there!
                  @watson
                    An alternative is that you can download the source code and compile it yourself.
                    • G
                      GACHAPO
                      I could, if I knew how.
                      I was hoping somebody would know why I cant use the burner?
                      • m5-docsM
                        m5-docs
                        Hello @GACHAPO @ajb2k3,
                        Now, you could burn camera board firmwares through the lastest m5burner. Please download the lastest version from www.m5stack.com
                        M5Stack documentation URL
                        https://docs.m5stack.com
                        • G
                          GACHAPO @m5-docs
                          @watson Thanks for coming back to me.
                          I have downloaded the new version and I have tried all three versions of cam software. None of them go into AP mode so I can browse to them. I have the Camera without the case so can you please let me know which software I use and how I get it sdet up beyond download.
                          • m5-docsM
                            m5-docs @GACHAPO
                            @gachapo Download a new one from www.m5stack.com, then burn ESP32CAM-v1.0.0. Your board is named ESP32CAM.
                            Here's the doc for it.
                            • G
                              GACHAPO
                              That's great thank you - works.
                              Is there any documentation about how to assign your own IP address to the camera please?
                              • m5-docsM
                                m5-docs @GACHAPO
                                @gachapo Do you mean this doc?
                                https://docs.m5stack.com/#/en/quick_start/m5camera/m5camera_quick_start
                                • G
                                  GACHAPO
                                  I've see that document and youtube video. I just need to know how to move the camera from M5stack AP connection on 192.168.4.1 to an assigned ip address by myself like 192.168.1.131?
                                    ajb2k3 @GACHAPO
                                    @gachapo you need to recompile the code is ST mode and upload to cameea
                                    • G
                                      GACHAPO @ajb2k3
                                      @ajb2k3 Thanks - Is there any documentation you can point me to please?
                                        ajb2k3 @GACHAPO
                                        • m5-docsM
                                          m5-docs @GACHAPO
                                          @gachapo At main.c file
                                          • G
                                            GACHAPO
                                            Hi - Can't find main.c file. I've been into the downloaded fiirwares and I can't see it. Where am I going wrong please?
