    SOFTWARE
    7
    69
    399.4k
    • G
      GACHAPO @m5-docs
      @watson Thanks - I have amended this. Am I best to use Arduino IDE to compile and upload? Currently when I use Arduino I have several error messages.
      • m5-docsM
        m5-docs @GACHAPO
        Hello @gachapo It's best to use esp-idf.
        M5Stack documentation URL
        https://docs.m5stack.com
        • G
          GACHAPO @m5-docs
          @watson Thanks- can you use arduino-ide?
          • m5-docsM
            m5-docs @GACHAPO
            Hello @gachapo,
            Yes, Color recognition arduino program may help you.
            Here's the code:
            https://github.com/m5stack/Applications-cam/blob/master/Camera/M5CamColorRecognition/M5CamColorRecognition.ino#L36
            • G
              GACHAPO @m5-docs
              @watson Thank you.
              Do I choose CAMERA_MODEL_WROVER_KIT?
              • m5-docsM
                m5-docs @GACHAPO
                @gachapo
                You need chang this source code about camera hardware configuration for adapting to ESP32CAM. Because the arduino source code is for M5Camera A model.
                // Select camera model
                //#define CAMERA_MODEL_WROVER_KIT
                #define CAMERA_A_MODEL_M5STACK_PSRAM
                //#define CAMERA_MODEL_AI_THINKER
                • m5-docsM
                  m5-docs
                  @GACHAPO @ajb2k3 Thanks your support
                  • G
                    GACHAPO @m5-docs
                    @watson I have downloaded the M5CamColourRecognition.ino and uploaded to camera successfully. I now have an issued IP address to my network, which I have browsed to and the software loads. However, when I either click get picture or start stream it doesn't work. Please advise?
                    • m5-docsM
                      m5-docs @GACHAPO
                      @gachapo Do you modify those pin map for adapting to ESP32CAM not M5Camera (A model)?
                      https://github.com/m5stack/Applications-cam/blob/master/Camera/M5CamColorRecognition/M5CamColorRecognition.ino#L62
                      #elif defined(CAMERA_A_MODEL_M5STACK_PSRAM)
                      #define PWDN_GPIO_NUM     -1
                      #define RESET_GPIO_NUM    15
                      #define XCLK_GPIO_NUM     27
                      #define SIOD_GPIO_NUM     25
                      #define SIOC_GPIO_NUM     23
                      #define Y9_GPIO_NUM       19
                      #define Y8_GPIO_NUM       36
                      #define Y7_GPIO_NUM       18
                      #define Y6_GPIO_NUM       39
                      #define Y5_GPIO_NUM        5
                      #define Y4_GPIO_NUM       34
                      #define Y3_GPIO_NUM       35
                      #define Y2_GPIO_NUM       32
                      #define VSYNC_GPIO_NUM    22
                      #define HREF_GPIO_NUM     26
                      #define PCLK_GPIO_NUM     21
                      • G
                        GACHAPO
                        Yes, as far as I'm aware as long as I have chosen the correct (or in this case closest match) at the top the defined pins should be loaded as below;
                        • m5-docsM
                          m5-docs @GACHAPO
                          @gachapo
                          • G
                            GACHAPO
                            Hello - I've downloaded before but I don't think it has .ino files so can't be used with Arduino.ide. Please advise?
                              ajb2k3 @GACHAPO
                              @gachapo said in [Solved] M5 Burner Firmware Option Update:
                              No, the driver is compiled with the espressiv IDF and so you need to install that and configure it to compile.
                              Something I have failed to do several times now.
                              • m5-docsM
                                m5-docs
                                can also program with arduino ide
                                • G
                                  GACHAPO @m5-docs
                                  @watson Ok - so frustrated was I with my first attempt I purchased a M5Camera ESP32 PSRAM. Works out of the box nicely, but only on it's own wifi (192.168.4.1). However, as previously I need to get onto my network.
                                  Therefore, using Arduino IDE I have gone to File, Examples, ESP32, Camera nd loaded up the sketch from there.
                                  I have then amended the SSID and Password to my own and defined the PSRAM camera as below;
                                  Compiles and uploaded the sketch.
                                  Nothing! - Camera doesn't even turn on.
                                  Can somebody please, simply tell me where I am going wrong and how you ever get this great product on your own network.
                                  • O
                                    Oyye @GACHAPO
                                    @gachapo
                                    I just registered for you :D
                                    Here what is solved my problem (Y2_GPIO_NUM):
                                    #elif defined(CAMERA_MODEL_M5STACK_PSRAM)
                                    #define Y2_GPIO_NUM 17 //32
                                    ajb2k3A G 2 Replies Last reply Reply Quote 0
                                      ajb2k3 @Oyye
                                      @oyye said in [Solved] M5 Burner Firmware Option Update:
                                      @gachapo
                                      Welcome to the forum!
                                      • G
                                        GACHAPO @Oyye
                                        @oyye Thank-you,
                                        I did as you stated with only change from the Arduino Examples being;
                                        This has made no change - Camera still does not come on.
                                        Just to be absolutely clear - this is the camera a have
                                        ![0_1556260445735_20190426_073011.jpg](Uploading 100%)
                                        • G
                                          GACHAPO
                                          Is anybody able to help me please? I now have 2 cameras and I am completely unable to get them on my wifi network as intended. Thank you
                                          • m5-docsM
                                            m5-docs @GACHAPO
                                            @gachapo Do you own M5Camera A model and B model? or ESP32CAM?
