    M5StickC internal battery disconnection
    General
    6.2k
    • D
      DavMartEs
      Is there a way to disconnect the internal battery of the M5StickC so it will be only on when power is supplied to USB-C plug?
      Cutting a wire?
      • L
        liushasha
        Sorry, the structure inside the device is totally fixed. It is not easy to disassemble it and keep the hardware good. Instead of charging the hardware side, do you prefer to program the power management IC and change the power supply priority? Details refer to the AXP192.
