IoT M5Cam Project - problems porting code
  • Dear all,
    I am trying to use a M5Cam as an IoT system. Long story short: I want to regularly take pictures, connect to a WiFi connection and upload them to a cloud service (in this case Google Cloud Storage, but any other sort of system would work). I found some github repo doing exactly what I need to do, but when trying to adapt it to my board, it crashes with the following error:
    E (489) spiram: Expected 8192KiB chip but found 4096KiB chip. Bailing out..
    I tried everything to force the board to recognise the 4Mb PSRAM:
    ESP32-specific
    CONFIG_ESP32_DEFAULT_CPU_FREQ_80=
    CONFIG_ESP32_DEFAULT_CPU_FREQ_160=
    CONFIG_ESP32_DEFAULT_CPU_FREQ_240=y
    CONFIG_ESP32_DEFAULT_CPU_FREQ_MHZ=240
    CONFIG_SPIRAM_SUPPORT=y
    SPI RAM config
    CONFIG_SPIRAM_BOOT_INIT=y
    CONFIG_SPIRAM_IGNORE_NOTFOUND=
    CONFIG_SPIRAM_USE_MEMMAP=
    CONFIG_SPIRAM_USE_CAPS_ALLOC=y
    CONFIG_SPIRAM_USE_MALLOC=
    CONFIG_SPIRAM_TYPE_AUTO=y
    CONFIG_SPIRAM_TYPE_ESPPSRAM32=
    CONFIG_SPIRAM_TYPE_ESPPSRAM64=
    CONFIG_SPIRAM_SIZE=-1
    CONFIG_SPIRAM_SPEED_40M=
    CONFIG_SPIRAM_SPEED_80M=y
    CONFIG_SPIRAM_MEMTEST=y
    CONFIG_SPIRAM_CACHE_WORKAROUND=y
    CONFIG_SPIRAM_BANKSWITCH_ENABLE=y
    CONFIG_SPIRAM_BANKSWITCH_RESERVE=8
    CONFIG_WIFI_LWIP_ALLOCATION_FROM_SPIRAM_FIRST=
    CONFIG_SPIRAM_ALLOW_BSS_SEG_EXTERNAL_MEMORY=
    Any ideas? I am a total noob with esp32 coding and so, but I would appreciate any help :) Also, if you happend to have some other example code I can take on, please share!
    Original Code:
    https://github.com/raphaelbs/esp32-cam-ai-thinker/tree/master/examples/google_storage
  • please choose psram size to 4MB0_1559292247701_bcc73ad7-e101-43f8-b252-3361553b63a6-image.png
  • Thanks @heybin ! That worked well (and it was surprisingly easy :) )
    Now I gotta fix some new problems...
    Stack smashing protect failure!
    abort() was called at PC 0x400d645d on core 0
    0x400d645d: __stack_chk_fail at /home/marta/esp/esp-idf/components/esp_common/src/stack_check.c:36
    Edit: Nevermind, i just needed to change the stack protection level from overall to normal. :)
  • Guess what? I hit another wall.
    It seems the camera is giving trouble, despite me configuring the pins as here:
    here
    E (218) camera: Camera probe failed with error 0x20001
    ESP_ERROR_CHECK failed: esp_err_t 0x20001 (ERROR) at 0x4008a228
    0x4008a228: _esp_error_check_failed at /home/marta/esp/esp-idf/components/esp32/panic.c:721
    file: "/home/marta/Arduino/esp32-cam-ai-thinker/examples/google_storage/main/main.c" line 195
    func: app_main
    expression: esp_camera_init(&camera_config)
    config XCLK_FREQ
      int "XCLK Frequency"
      default "20000000"
      help
          The XCLK Frequency in Herz.
    menu "Pin Configuration"
        config D0
            int "D0"
            default "32"
        config D1
            int "D1"
            default "35"
        config D2
            int "D2"
            default "34"
        config D3
            int "D3"
            default "5"
        config D4
            int "D4"
            default "39"
        config D5
            int "D5"
            default "18"
        config D6
            int "D6"
            default "36"
        config D7
            int "D7"
            default "19"
        config XCLK
            int "XCLK"
            default "27"
        config PCLK
            int "PCLK"
            default "21"
        config VSYNC
            int "VSYNC"
            default "25"
        config HREF
            int "HREF"
            default "26"
        config SDA
            int "SDA"
            default "4"
        config SCL
            int "SCL"
            default "13"
        config RESET
            int "RESET"
            default "15"
    endmenu
