    M5burner on windows7 cannot flash
    28 Posts 5 Posters 101.4k Views 1 Watching
    • Ariane98A Offline
      Ariane98
      btw, in arduino, how do you access the built in red led?
      Docs showed pin 10 but it's no working...
        ajb2k3 @Ariane98
        @ariane98 said in M5burner on windows7 cannot flash:
        Try GPIO10
        Ariane98A 1 Reply Last reply Reply Quote 0
        • Ariane98A Offline
          Ariane98 @ajb2k3
          Strangely, it does light the led when I use digitalWrite(10, HIGH) but then nothing happens with digitalWrite(10, LOW)
          If I use digitalWrite(10, LOW) first, it sets the led ON...
            Ok I'm running 1.4 and getting a syntex error.
            Try upgrading to 1.4.0 beta and try again.
            • Ariane98A Offline
              Ariane98 @ajb2k3
              Thanks for your help
              I intended to use m5stick with kids but maybe it's too early...
              Both UIFlow and Arduino environments seem still unpredictable
                ajb2k3 @Ariane98
                @ariane98 Its strange because all I use is UIFlow and I am writing an english book on it (samples available to download in the projects forum)
                For the current M5StickC competition i'm using the IMU in my project however, I'm using the online version and programming over wifi.
                Ariane98A 2 Replies Last reply Reply Quote 0
                • Ariane98A Offline
                  Ariane98 @ajb2k3
                  I am using UIFlow online too, but no luck with IMU...
                  • Ariane98A Offline
                    Ariane98 @ajb2k3
                    is it possible too use the stick as a vry simple webserver?
                      Don't know about the web server but here is my imu test file
                      https://github.com/Ajb2k3/UIFlowHandbook/blob/master/main (8).m5f
                      • Ariane98A Offline
                        Ariane98 @ajb2k3
                        I get the same I2C bus error
                        If I upload it to the stick I get a grey screen with no data displayed
                        • Ariane98A Offline
                          Ariane98 @Ariane98
                          updated to 1.4.0 beta and that's OK now
                          Thank you
                          I've looked at your book...quite nice
                            ajb2k3 @Ariane98
                            Thank you
                            Its still WIP and I am open to comments a criticism.
                            • lukasmaximusL Offline
                              @Ariane98 you can check out my guide for simple webserver, it's written for the M5Stack in micropython, but you shouldn't have any problems running it on the stick c https://www.hackster.io/lukasmaximus89/m5stack-micropython-simple-web-server-20a4c4
                              I'm curious to know what age students were you thinking of using the stick c to teach with?
                              • Ariane98A Offline
                                Ariane98 @lukasmaximus
                                @lukasmaximus
                                kids from 8 to 14
                                I've had workshops with "bare" ESP32 and an online coding tool
                                Interesting but too complex to be fun for kids
                                • Ariane98A Offline
                                  Ariane98 @Ariane98
                                  @ariane98
                                  Regarding you guide, I uploaded it and the screen shows 4 "Labels" saying Text. It does not mention wifi connexion, or failed connexion
                                  • Ariane98A Offline
                                    Ariane98 @Ariane98
                                    @ariane98
                                    It works now, after some minor changes
                                    Thanx again
