    M5Stack LoRa and ThingSpeak
    esp32c++arduino
    3 Posts 2 Posters 9.4k Views 1 Watching
      thenecniv
      I am trying to upload data to thingspeak that is being received from the LoRa Unit via Arduino, but so far all I have been able to upload are data that is irrelevant.
      The Arduino example shows that on the receiving end of LoRa, there is a line where the M5 read the packet sent, but simply uploading the said packet does not work, and ends up with 48/50.
      Said Code section is :
      while (LoRa.available()) {
      char ch = (char)LoRa.read();
      Serial.print(ch);
      M5.Lcd.print(ch);
      int x = ThingSpeak.writeField(myChannelNumber, 1, ch, myWriteAPIKey);
      if(x == 200){
      Serial.println("Channel update successful.");
      delay(10000);
      else{
      Serial.println("Problem updating channel. HTTP error code " + String(x));
      delay(10000);
      Is there anyway to upload that data? Thanks!
      • m5stackM Offline
        i have not idea. we never try upload data to thingspeak before. and share your application logic and your actual use functions . maybe another people can help you. thanks
          thenecniv
          So, I have 2 m5stack core with me.
          My idea is to have these 2(or potentially more) to communicate with each other via LoRa, one to be a sensor node, and another acts as a receiver.
          The receiving node will then upload the data received from the sensing node to thingspeak.
          The components used in this system is the ENV sensor, and the LoRa modules.
          I hope this explains what I am trying to do.
