    [SOLVED]M5Stack basic I2C pull-up resistor
    Cores
    10.7k
    • C
      cepics
      Hi all, are they present the pull-up resistors in the M5Stack (black 2018.3) I2C section?
      I'm trying to read this US sensor but I don't know if add or not pull-up resistors.....
      tnks
      • C
        cepics
        nobody??
        • m5stackM
          it already has pull up resistors in G21/22 ( the I2C PIN)
          • C
            cepics
            tnks a lot!!,
            wich value?
            can I disable it?
            I'm in Arduino ecosystem ...
            • m5stackM
              m5stack @cepics
              @cepics The default resistance is 3.3k. you cannot disable it. If you want to dismantle it. Operation will be more difficult
              • C
                cepics
                tnks a lot!!!
