I cannot burn anything on my cardputer using my Mac it gives some strange error, can someone help me here?
--chip auto --port /dev/tty.usbmodem14201 --baud 1500000 --before default_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0x000 /Applications/M5Burner.app/Contents/Resources/packages/firmware/aeb96d4fec972a53f934f8da62ab7341.bin
File "/Applications/M5Burner.app/Contents/Resources/packages/tool/esptool.py", line 17, in <module>
import esptool
File "/Applications/M5Burner.app/Contents/Resources/packages/tool/esptool/init.py", line 816
raise FatalError(f"Unable to verify flash chip connection ({e}).")
SyntaxError: invalid syntax -
@somuchlight Thats because USB modem isn't the cardputer.
@ajb2k3 thanks so much i got to know a thing about it. But even when I am trying everything as shown in the video I still recieving this error! The thing is I burned m5 launcher is that hindering it ?I removed my sd card and then burned the default Ui firmware but still somehow M5 launcher is there and so when I am trying to burn Ui flow it shows this error
import esptool
@somuchlight Sounds like the Cable is not a data cable
@somuchlight
Try changing the computer, changing the cable, etc... -
@ajb2k3 sure I will try changing the cable and give it a try. Thanks a ton again!
@kuriko Sure I will try changing the cable cannot change the system as i just have a macbook. Thanks for your response!
@somuchlight I run OSX as well and there are several problems it could be.
1, Bad cable,
2, you didn't put the Cardputer in boot mode,
3, M5Burner has not been installed to the desktop,
4, You haven't Installed the latest Python,
5, You haven't installed the ESPtool. -
@ajb2k3 ok good and yes you are right, I did check everything including drivers finally I found a solution it was super hectic but it works now!
first thing as you stated earlier was to change cables so I got a new data cable(android phone cable which I was using earlier didn't work) it gave me same issue but then this is what I did
Quit M5 burner app > went to Applications > M5 burner app in Applications > Control + Click > Show package contents > Contents >Mac Os folder > Click on M5 burner (EXEC) terminal and let it run, this opened another M5 burner window in a few seconds.
after this I downloaded UI flow again then followed the process in the previous youtube link shared by you also before erasing I changed the baud rate to 964100. Now If I open M5 burner from desktop it gives me the same issue but the issue resolves if I open using the terminal thing as stated above, I realised the error itself sort of held te solution I just followed where it was trying to send me. Currently using Mac os Mojave 10.14.6. Truly grateful for your support and everyone who commented!
