@ajb2k3 ![
i get this error message
B
Save
Saving
bww1340
@bww1340
0
Reputation
550
Profile views
0
Followers
0
Following
Posts made by bww1340
RE: UI flow - connexion problem usb port
@ajb2k3 Thanks for you message. Indeed, I didn't configure correctly. now is it connected !
I can run a program but it is not possible to download the code in the stick
Hello
I just start with M5stick-C and i have some problem
I have installed m5burner and it works fineI tried Ui flow and impossible to connect to the m5stack-c..
When I connected to the pc on windows 10, it s seen as usb serial port (com3)..
I use this port in ui flow and impossible to connect...Any idea ?
Thanks for you helo
