@skink Thanks for your answer
Posts made by Jean-Claude
    How to recharge the batteryposted in M5 Stick/StickCI just get my first M5StickC and I am wondering how to recharge the internal battery? I try to connect to a USB IPhone 5v plug for 3 hours but I just get 5 minutes run time. What do you recommend and how do you know when the battery is full? Thanks in advance.
    Failed to read register addressposted in ArduinoHello
 I just receive my M5Stack C, I went thru the install using Arduino but I always get an error during upload ( I run the Factory sketch test)"esptool.py v2.6
 Serial port /dev/cu.usbserial-3D52321EB6
 Connecting........___
 Chip is ESP32-PICO-D4 (revision 1)A fatal error occurred: Failed to read register address 6001a00c (result was 01050000)
 A fatal error occurred: Failed to read register address 6001a00c (result was 01050000)I use 115200 speed, ESP pico Kit as board, M5StickC library is install Any advice please.
 Thanks in advance
 Jean-Claude
