I'm charging a battery for 2 hrs from off state already and vbat still 3.46V (((
Best posts made by vvs551
RE: Unreal power discharge / charge currentposted in M5 Stick/StickC
M5StickC does not scan I2C sensor at (0,26) pins (Hat pins)posted in M5 Stick/StickC
There is limited workable G0 pin at M5StickC in the current version of the hardware!
It's could not possible to scan I2C sensor at (0,26) pins
At the same time, there is no problem for (32,33) or (32,26) pins
There was not such a problem in the older version of hardware M2StickC
This problem take place just for some kinds of I2C sensors, f.e. SGP30
Latest posts made by vvs551
Most of img.draw_string() parameters are not usableposted in M5Stick V
There is absent any influence at the image in the screen a lot of parameters of img.draw_string()
F.e. char_rotation, char_vflip, string_rotation, string_hmirror, string_vflip
Is anybody could change this values from the default statement? -
After sensor.set_hmirror(True) all colors are changeposted in M5Stick V
Why after sensor.set_hmirror(True) there are change colors?
As a result, there is impossible to use find_blobs by color after hmirror! ( -
This problem take place just for some kinds of I2C sensors, f.e. SGP30 -
@multihelix
Why not, but .. why?? )
It's nothing doing in this sketch ) -
I have received a new m5stick-c from M5Stack Official Store and was shocked by unreal discharge and charge currents
There are 127 mA and 9 mA (from discharging state) in the official example
In my first m5stick-c there were 82 mA and 87 mA
Is anybody have an idea how to improve this terrible situation?!
RE: How to restore display after M5.Axp.SetSleep() with code?posted in M5 Stick/StickC
@ricardocosta
void AXP192::SetSleep(void){Wire1.beginTransmission(0x34); Wire1.write(0x31); Wire1.endTransmission(); Wire1.requestFrom(0x34, 1); uint8_t buf = Wire1.read(); buf = (1<<3)|buf; Wire1.beginTransmission(0x34); Wire1.write(0x31); Wire1.write(buf); Wire1.endTransmission(); Wire1.beginTransmission(0x34); Wire1.write(0x12); Wire1.write(0x41); Wire1.endTransmission();}
