    UIFlow 1.6.3
    Official Updates
    9
    19
    35.8k
    • m5stackM
      UpdateLog:
      Ver 1.6.3 time : 2020.09.11
      firmware:
      • V-Function: support Line Tracker&Tag reader..
      • Image: PNG support..
      • StickC-Plus beep support..
      • IR unit bug fix..
      • Therad mutex bug fix..
      • Other bugs fix..
      • Core2: Speaker support(Only support play WAV file for now)..
      • Core2: Vibration motor intensity setting support..
      • Core2: Checkbox widgets support..
      • Core2: Slider bar widgets support..
      • Core2: Bar widgets support..
      web:
      • Add: V function support Line Tracker&Tag reader..
      • Add: Core2 Slider, Bar, Checkbox component.
      • Fixed some bugs.
      • K
        Kris @m5stack
        @m5stack where is TCOC/eCO2 unit?
        • T
          Thrasher
          @m5stack hello m5stack could you tell me please if I can use StickV with UIFlow now (connected to core module or stickC)? Or is it possible only with unitV?
          Thanks in advance
          • SkinkS
            Skink
            @m5stack
            UiFlow Beta Core2 ,
            here nothing can be selected under Hardware function Power
              ajb2k3 @Skink
              @skink said in UIFlow 1.6.3:
              @m5stack
              UiFlow Beta Core2 ,
              Just tried and it works for me. What exactly is not happening?
              • SkinkS
                Skink @ajb2k3
                Ah, that seems to be a problem in the language German in the English everything works.
                1. picture Core 2 Language "English
                2. picture Core 2 Language "German"
                In the English version I have several options under Hardware Power which I can select.
                In the german version these are missing and the two that are displayed are on top of each other and cannot be selected !!
                  @m5stack there is an alignment issue with the German version of the Web UIFlow, looks like the formatting has been broken.
                  • V
                    veryalien
                    The vibration motor intensity setting has no effect. Setting it to any value between 0 and 100 does not change the motor at all. The motor is always fully on when it is enabled.
                    • m5stackM
                      m5stack @ajb2k3
                      @ajb2k3 thanks feedback. we will fix it ASAP
                      • K
                        klapaucius
                        This may be a super stupid question but where are the download links for the recent firmwares ?
                        On MacOS, M5burner shows just and empty screen. The flow.m5stack.com site does not show firmware download links (just links to the m5burner tool containing no firmware).
                        https://github.com/m5stack/M5Stack-Firmware/blob/master/firmware-repo.list only shows outdated firmware (which I can upload manually using the flash.sh script after sufficient massaging).
                        Also note that the UIflow desktop app does not seem to work - it looks like the baud rate might be too high for the mac.
                        Thanks in advance for clarifying!
                        • K
                          kurthofman
                          Hello, I've upgraded my M5Stack Fire too 1.6.3 but the device doesn't boot anymore.
                          I get :
                          E (433) esp_image: invalid segment length 0xffffffff
                          E (433) boot: Factory app partition is not bootable
                          E (433) boot: No bootable app partitions in the partition table
                          Can this be solved !
                            ajb2k3 @kurthofman
                            @kurthofman to you upgrade to the correct version of 1.6.3?
                            there is 3 versions for the core
                            • K
                              klapaucius @ajb2k3
                              Is there a download link for the latest firmwares ? The M5burner on MacOS seems broken (I can into details if you want me to), but I can flash firmware manually without problems. But I can't find download links published anywhere.
                              Many thanks in advance!
                              • K
                                klapaucius @ajb2k3
                                • SkinkS
                                  Skink
                                  @kurthofman
                                  Here is a breakdown of the versions for the respective M5 Core's
                                  what I don't know exactly is if M5 Core Lite and M5GO are not also part of M5Core Fire.
                                  • SkinkS
                                    Skink @veryalien
                                    @veryalien
                                    Yes I have to agree with you, I have the same problem.
                                    With "Set vibration intensity" alone the vibration motor does not work at all, no matter if 1-100%.
                                    If I switch it on with "Set vibration enable (true)" the motor will vibrate but with the same intensity, I try to change the intensity with "Set vibration intensity" but nothing happens.
                                    I can only switch it off with "Set vibration enable (false)"!
                                      ajb2k3 @Skink
                                      @skink the lite and the go are Mark 1 cores
                                      • G
                                        GMAN
                                        Bug report: firmware 1.6.3-en is not installing on M5 stack core (black) 1.6.2 does.
                                        • m5stackM
                                          m5stack @GMAN
                                          @gman what is your mean? can't install the firmware file? or can't burn the firmware? could you say more detail?
