    "Timed out waiting for packet header"
    6 Posts 2 Posters 15.4k Views
      F3l1x
      Hi
      Trying to follow an official M5 tuto, I want to upload the arduino code to the Fire board.
      I get a time out error. Full message :
      Arduino : 1.8.1 (Windows 7), Carte : "M5Stack-FIRE, Enabled, Default (2 x 6.5 MB app, 3.6 MB SPIFFS), 115200, None"
      esptool.py v2.6
      Serial port COM26
      Connecting......................................____Une erreur est survenue lors du transfert du croquis
      _
      A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header
      I tried many baudrates, with no luck
      Some people say it is because we need to hold-down the “BOOT/FLASH” button while uploading ...is there a simple way to do it with the Fire board ?
        F3l1x
        Sooooo...
        The arduino code did upload - I don't know why!
        But the program did not show anything so I tried to edit it, and now it won't upload.
        So I thought it was something about the USB mode. Unfortunately, I don't have the setup option anymore
        So I tried burning the 1.6.2 firmware again...M5Burner fails with this message:
        Chip is ESP32D0WDQ6 (revision 1)
        Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse
        MAC: a4:cf:12:44:6d:d0
        Uploading stub...
        Running stub...
        Stub running...
        Configuring flash size...
        Warning: Could not auto-detect Flash size (FlashID=0xffffff, SizeID=0xff), defaulting to 4MB
        A fatal error occured: File C:\Users\zzz\Downloads\M5Burner\packages\fw\other\wifi.bin (length 100) at offset 6287360 will not fit in 4194304 bytes of flash. Use --flash-size argument, or change flashing address
        Burned failed
        I feel so stupid...
        • m5stackM Online
          try to remove the FIRE battery bottom
          try to erase the flash by M5Burner
          then try upload the UIFlow firmware agian.
          if still don't work. you could contact the store
            F3l1x
            Thanx...everything back to normal
            Is there a way to mark topic as [solved] ?
              F3l1x
              Oups...not solved at all
              It did it again and again. Won't flash from arduino IDE
              Arduino : 1.8.1 (Windows 7), Carte : "M5Stack-FIRE, Enabled, Default (2 x 6.5 MB app, 3.6 MB SPIFFS), 115200, Debug"
              C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\2.6.1/esptool.exe --chip esp32 --port COM26 --baud 115200 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0xe000 C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/partitions/boot_app0.bin 0x1000 C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/bin/bootloader_dio_80m.bin 0x10000 C:\Users\xxx\AppData\Local\Temp\arduino_build_345911/FireScreen.ino.bin 0x8000 C:\Users\xxx\AppData\Local\Temp\arduino_build_345911/FireScreen.ino.partitions.bin
              esptool.py v2.6
              Serial port COM26
              Connecting........___.....
              Uploading stub...
              Running stub...
              Stub running...
              Compressed 8192 bytes to 47...
              A fatal error occurred: Timed out waiting for packet content
              I did erase and reflash firmware...fail again
              I'm getting mad at this Fire thing
              So promising and so disappointing!
                F3l1x
                Getting worse...M5burner won't even erase now
                Erase now
                esptool.py v2.5.0
                Serial port COM26
                Connecting........_
                Detecting chip type...
                It stays there for ever
                Pliz someone help me ?!
