    M5Stack Grey charging 16580 LiPo
    2 Posts 2 Posters 4.0k Views
      robouden
      Hi all,
      I have designed a board with the M5Stack grey on it and the battery is a 16580. But it only chargers at about 120mA. How to set the IP5306 to charge at higher currents?
      regards,
      Rob Oudendijk
        Hi Rob
        if you look into Power.cpp you'll see that the current already is set to about 400 mA:
        https://github.com/m5stack/M5Stack/blob/master/src/utility/Power.cpp
        void POWER::begin() {
          uint8_t data;
          //Initial I2C
          Wire.begin(21, 22);
          // 450ma
          setVinMaxCurrent(CURRENT_400MA);
        are you calling M5.Power.begin() in your setup code?
        Or maybe the current has been reduced due the the battery being close to full?
        Cheers
