    M5Burner on linux mint doesn't work
    Bug Report
    5.7k
    • L
      L0cutus
      after i start to burn the UIFlow to my M5Stick Plus i obtain this errors:
      Start Burn
      --chip esp32 --port /dev/ttyUSB0 --baud 750000 --before default_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0x3ff000 /home/l0cutus/Scaricati/M5Burner/packages/fw/other/wifi.bin 0x1000 /home/l0cutus/Scaricati/M5Burner/packages/fw/stickc/UIFlow-v1.6.4-plus.bin
      File "/home/l0cutus/Scaricati/M5Burner/packages/tools/esptool.py", line 21, in <module>
      import argparse
      File "/usr/lib/python3.8/argparse.py", line 88, in <module>
      import re as _re
      File "/usr/lib/python3.8/re.py", line 145, in <module>
      class RegexFlag(enum.IntFlag):
      AttributeError: module 'enum' has no attribute 'IntFlag'
      Error in sys.excepthook:
      File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 62, in apport_excepthook
      if not enabled():
      File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 24, in enabled
      import re
      Original exception was:
      import argparse
      import re as _re
      Burn Failed
      Any idea ?
      Thanks !
      • ozbkO
        ozbk
        Remove the packages/tools/enum in the M5Burner directory and try it again.
        • L
          L0cutus
          GREAT! it worked thanks!
