    Pins in UIflow
    UIFlow
    8.9k
    • K
      Kris
      Which physical pins on the M5stack and M5stick correspond to pins 0-5 in UIflow?
        Hi @Kris
        that is entirely up to you - pin0-4 are just variables.
        In UIFlow use the first statement to initialise the desired GPIO (0-36) to be used with one of the 5 variables (pin0-4).
        MicroPython example: variable pin0 is used for GPIO18:
        pin0 = machine.Pin(18, mode=machine.Pin.IN, pull=machine.Pin.PULL_UP)
        Cheers
        K A 2 Replies Last reply Reply Quote 0
        • K
          Kris @felmue
          @felmue thanks,
          • A
            Alex28 @felmue
            if i want to use more than 5 pins,what shall I do ?
              Hello @Alex28
              in the end pin0 - pin4 are simply Micropython variables, so either switch to the Micropython tab or use Execute code blocks to add more pinX variables.
