    Avoid LCD Flicker When Updating Text on M5StickC?
    Micropython
    5
    6
    13.9k
    • J
      JackH
      I measure quantities and display them every tenth of a second or so. The screen flickers annoyingly.
      I have tried lcd.clear() and overwriting with the previous text with lcd.Black color in between writes but they both flicker the same way. printing '\r' on each line before writing text doesn't work either.
      Other suggestions?
      • m5stackM
        try use M5.Lcd.fillRect(x,y,w,h,color); to cover display the value. don't need clear whole screen
          Hello @JackH
          Here is my attempt to reduce flicker for a simple counter. The code separates the digits and only updates the ones which are necessary. The flicker isn't completely gone, but at least only the digit which changes flickers a little bit.
          from m5stack import *
          from m5ui import *
          from uiflow import *
          import time
          setScreenColor(0x000000)
          count0 = None
          oldten0 = None
          one0 = None
          ten0 = None
          from numbers import Number
          import math
          count0 = 0
          oldten0 = 0
          for count in range(30):
            one0 = count0 % 10
            lcd.print(one0, 20, 5, 0x000000)
            count0 = (count0 if isinstance(count0, Number) else 0) + 1
            one0 = count0 % 10
            lcd.print(one0, 20, 5, 0xff0000)
            ten0 = math.floor(count0 / 10)
            if ten0 != oldten0:
              lcd.print(oldten0, 5, 5, 0x000000)
              lcd.print(ten0, 5, 5, 0xff0000)
              oldten0 = ten0
            wait_ms(300)
          BTW: In the Arduino environment a solution to reduce flicker is to use sprites, but I have no idea if sprites exist in M5Stack's MicroPython implementation.
          Cheers
          • R
            robalstona
            I am using the lcd.print function. I add one or two spaces to the displayed value and display in the same place. In firmware version 1.4.5 UiFlow, this function displays text with a black background (default), blurring previously displayed text completely. And there is no display flickering effect. Unfortunately, in version 1.5 the background of the text is transparent and the following text overlaps. I don't know how it is solved from version 1.6 and higher.
            or try below commands in execute block
            Print text on screen, x and y is beginning cursor , use current foreground color is not given
            lcd.print(text, x, y, [,color])
            Set the default foreground color
            lcd.set_fg(color)
            On 1.4.5 firmware looks like:
            https://youtu.be/EzupP4tXkZA
            • J
              JackH @felmue
              Thanks @felmue and @robalstona , I will try your suggestions tomorrow.
              Jack
              • A
                anuradhawick
                You can always use sprites to get rid of flicker. It happens because you write to LCD in runtime which is slow. Try sprites;
                First, create a sprite and set the size. Then fill it in black to avoid overwriting text.
                disp_buffer = new TFT_eSprite(&M5.Lcd);
                disp_buffer->setSwapBytes(false);
                disp_buffer->createSprite(240, 135);
                disp_buffer->fillRect(0, 0, 240, 135, BLACK);
                Then write desired text and push it to screen.
                disp_buffer->drawString("This is some text", 0, 0, 2);
                disp_buffer->pushSprite(0, 0);
