    Bus Mapping M5Core2 <-> M5Stack
    10 Posts 5 Posters 20.2k Views 1 Watching
      sheepDog
      in past I used some M5Stack modules at M5Stack and now I like to migrate to M5Core2. The challenge ist the different bus system.
      Pin	M5Stack	M5Core2
      GND	2	1,3,5
      SCK	4	11
      MISO	6	9
      RESET	8	6
      nu	10	-
      nu	12	-
      A0	14	-
      A1	16	-
      A2	18	-
      A3	20	-
      A4	22	-
      A5	24	-
      AREF	26	-
      IO12	28	-
      IO13	30	-
      5V	1	28
      MOSI	3	7
      SS	5	-
      D0/RX	7	13
      D1/Tx	9	14
      D2/SDA	11	SYS:17, EXT:19
      D3/SCI	13	SYS:18, EXT:20
      D4	15	-
      D5	17	-
      D6	19	-
      D7	21	-
      IO8	23	-
      IO9	25	-
      IO10	27	-
      IO11	29	-
      IO35	-	2
      IO36	-	4
      IO25	-	8
      IO26	-	10
      3,3V	-	12
      Rx2	-	15
      Tx2	-	16
      IO19	-	22
      IO0	-	24
      IO34	-	26
      BAT	-	30
      Who has experience with using an M5Stack module on an M5Core2?
      • m5stackM Offline
        Core2-bus has some differences with M5-bus. so when you stack the module to the core2. you need to make some pin num change in your code.
          Hi guys
          I've put together a comparison sheet showing the similarities and differences between M5Stack / M5Core2 bus and GPIO usage. You can find it here:
          https://www.gwendesign.ch/kb/m5stack/m5core2/#m5core2-bus-and-gpios-compared-to-m5stack
          Cheers
          • m5stackM Offline
            m5stack @felmue
            @felmue Thank you for your help.
            • N Offline
              Nlindin @m5stack
              @m5stack Hi! Could you please put an example? I can not find a valid one. For example, how can we -using arduino- mix Core2 and GoPlus2 module? The example does not work. Thank you very much!
                ajb2k3 @Nlindin
                @nlindin what is arduino- mix Core2 ?
                Go plus2 is sat on my bench waiting to be documented when i finish the coreink but had some issue with the coreink delaying documentation.
                N 2 Replies Last reply Reply Quote 0
                • N Offline
                  Nlindin @ajb2k3
                  @ajb2k3 Thank you for your answer. I want to say an example in arduino for Core2+Goplus2. With Uiflow it seems to work fine. With Arduino I am totally stuck in this scenario.
                  • N Offline
                    Nlindin
                    Hi again!
                    For now I have changed the .ino from GPIO 5 to GPIO 33, (35 is the same for both, Stack and Core2) but the ir receiver gives only "PARAM LEN ERROR" from all my remotes and buttons. I continue doing something wrong with the Core2+Goplus 2.
                    Any help, please?
                    Thank you!
                    • N Offline
                      Nlindin @ajb2k3
                      @ajb2k3 The IR in the GoPlus2 gives this by the serial monitor. Any updates?
                      Thank you and happy 2021.
                      E (42353) rmt: rmt_write_items(797): RMT PARAM LEN ERROR
                      send done
                      76
                      recv done
                      76
                      • N Offline
                        Nlindin @Nlindin
                        @nlindin This one works!
                        #include <M5Core2.h>
                        #include <IRremote.h>
                        IRrecv irrecv(35);
                        decode_results ircode;
                        irrecv.enableIRIn();
                        void loop()
                        if (irrecv.decode(&ircode))
                        Serial.println(ircode.value, HEX);
                        delay(100);
                        irrecv.resume();
                        m5.update();
