    M5 Stick C : "Guru Meditation Error: Core 0 panic'ed (LoadProhibited)"
    Units
    4.8k
    • H
      heleb
      Using Arduino 1.8.12 , Library: M5StickC 0.2.0
      My M5Sticks run anywhere from 2days to 3 weeks and then crash.
      The crash typically happens right after some WiFi networking call.
      For example:
      crash after: http.begin(g_wClient , g_cHttpCmd);
      or crash after : iRSSI = WiFi.RSSI();
      After the crash, the M5 Stick C does not automatically reboot , which I believe it should
      Attached is the debug output:
      21:16:28.890 -> Guru Meditation Error: Core 0 panic'ed (IllegalInstruction). Exception was unhandled.
      21:16:28.890 -> Memory dump at 0x40082868: 03adf784 c0079ea5 40082920
      21:16:28.890 -> Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled.
      21:16:28.924 -> Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled.
      21:16:28.959 -> Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled.
      21:16:28.993 -> Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled.
      21:16:29.027 -> Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled.
      21:16:29.060 -> Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled.
      21:16:29.094 -> Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled.
      21:16:29.128 -> Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled.
      21:16:29.163 -> Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled.
      • H
        heleb @heleb
        Reduced CPU from 240MHz to 80MHz ----Problem seems to be gone
        Hmmmmm.... shaky hardware?
        • m5stackM
          In this situation, we haven't met. our all firmware is used 240MHz default. maybe you could check it does related to your program.
