    M5 Stick C Plus and Arduino IDE - not Port visible
    M5 Stick/StickC
    5.6k
      MikeMuc68
      Hello, I'm running Mac OS Catalina 10.15.6 and I'm not able to get the serial port running with my M5 Stick C Plus and Arduino IDE. I've already installed the CP210X driver.
      I´ve tried it with a MS Surface PC as well - same problem. I've used the delivered USB cable, but also a different one - without success.
      Could it be that the device is not OK ?
      Thanks,
      Michael
        MikeMuc68
        SOLVED, I´ve tried a different driver found via Google search an now the upload works.
        • ZontexZ
          Zontex
          Hi Mike! happy you solved it, would you mind sharing what driver you used? we have shared on our M5Stack documentation how to install drivers for different system, have you tried to follow that? it didn't work for you?
