    Can't instantiate MQTT class (M5 Stick C Plus with Micropython)
    Micropython
    5.4k
    • R
      rousveiga
      Hello! I have a small MicroPython program running on my M5 Stick C Plus (with UI Flow firmware version 1.6.5.1-plus, as I get screen errors with 1.6.6-plus) and I wanted to add MQTT communication. I was following loboris' documentation and examples. However, I get the following error:
        File "main.py", line 289, in <module>
      AttributeError: 'module' object has no attribute 'mqtt'
      MicroPython 7021d9419-dirty on 2020-10-30; M5StickC-Plus with ESP32
      Line 289 looks as follows (I imported network earlier in the code):
      client = network.mqtt(NAME, SERVER, user="mosquitto", password="mosquitto", cleansession=True, connected_cb=conncb, disconnected_cb=disconncb, subscribed_cb=subscb, published_cb=pubcb, data_cb=datacb)
      I'm completely dumbfounded, as the same method call appears in the M5 Cloud MQTT example. Does anybody know what could be causing this behavior?
      Thanks in advance,
      Rosa
      • sodokuS
        sodoku
        If I use the mqtt blocks in UIFlow.1.6.6 it generates the following python code:
        from m5mqtt import M5mqtt
        m5mqtt = M5mqtt('NAME', 'SERVER', 1883, 'mosquitto', 'mosquitto', 300)
        m5mqtt.publish(str('topic'),str('message'))
        • R
          rousveiga @sodoku
          @sodoku I see! I'll try that code. Thank you!
