    Cable for motor encoder module
    Modules
    3.9k
    • R
      ramaker
      It's me again.....
      Where can I find / buy cales for connecting a encoder motor to the module ?
      I can find cables for connecting LEGO motors - but were are the cables 6-pol to 6-pol ?
      • sodokuS
        sodoku
        Those are fairly standard cables and I am not aware of M5Stack selling them.
        You can find them at electronic stores, Amazon, ebay..
        I think the connector is called "jst sh 6 pin".
        • R
          ramaker
          @sodoku said in Cable for motor encoder module:
          jst sh 6 pin
          Ok - I found it.
          Thank you.
          • R
            ramaker
            "jst sh 6 pin".
            Oh ... I see a big problem !
            There are 1m, 1,25,, and 2,5 mm conectors and I think they are the 1mm types using.
            But I cannot find one with longer wire - only 10 or 15 cm with open end cables. Open end would be no problem, but I need minimum 30cm - 50 cm would be best.
            Can anyone from M5Stack give me an order source , please.
