    drawJpgFile / drawBmpFile
    30 Posts 4 Posters 145.1k Views 2 Watching
      Richard @Calin
      @calin
      thanks,
      I tried but I still have the problem!
      no idea
        Calin
        Please share your code so i can check and see what's the problem there.
          Richard
          my code
          #include <M5Stack.h>
          void setup(void) {
          M5.Lcd.setBrightness(200);
          M5.Lcd.drawJpgFile(SD, "/corto.jpg"); // Load background from SD
          //M5.Lcd.drawJpgFile(SD, "/corto_1.jpg", 0, 20, 300, 200);
          // M5.Lcd.drawJpgFile(fs::FS &fs, const char *path, uint16_t x, uint16_t y, uint16_t maxWidth, uint16_t maxHeight, uint16_t offX, uint16_t offY, jpeg_div_t scale);
          M5.update();
          delay(1000);
          Thank you
            Richard
              Richard
              m5stack from m5stack store
                Richard
                  Calin
                  Here is the test using your code (with small modifications and relevant comments)
                  and standard m5Stack library from PlatformIO:
                  And here is the result:
                    Richard
                    fine, but does not work on ide arduino.
                    can you send me your code in espi setup?
                      Richard
                      do you have tested my with arduino ide?
                      thank you
                        Richard
                        i have install PlatformIO and load my projet:
                        Wrote 230992 bytes (123957 compressed) at 0x00010000 in 11.0 seconds (effective 168.6 kbit/s)...
                        Hash of data verified.
                        Leaving...
                        Hard resetting via RTS pin...
                        ====================================================== [SUCCESS] Took 23.68 seconds =======================================
                        hardware problem?
                        I
                          Agreed, Following this myself and just get a blank screen with the image not loaded. This is my image 0_1529644400361_logo.jpg
                            Calin @Richard
                            @richard No. i didn't tested with arduino "ide". I uninstalled that from my PC because is mostly useless...
                            I use Visual Studio, Eclipse or PlatformIO.
                            I uploaded the PlatformIO project for your code to github: https://github.com/botofancalin/M5StackJpgtest
                            The M5Stack library is already installed local into project.
                            All you have to do is to download the repository and compile the code.
                              ajb2k3 @Calin
                              @calin 在 drawJpgFile / drawBmpFile 中说:
                              Maybe a stupid question (or two) but I'm going to ask anyway.
                              Is there a hardware limitation for this i.e. is there a card size limit and a formatting requirement?
                              Is there a specific image limitation for the image?
                                Richard
                                I use Visual Studio too.
                                i have just tested your programm and i still have the problem.
                                I think it's a hardware problem.
                                I'm waiting for another device
                                Thank you.
                                  Calin @Richard
                                  @ajb2k3 在 drawJpgFile / drawBmpFile 中说:
                                  I think there is no limitation on card size.
                                  There might be a limitation on card read/write speed and that depend on the sdcard manufacturer and model.
                                  As i know, the cards formatted as FAT32 are preffered.
                                  @richard 在 drawJpgFile / drawBmpFile 中说:
                                  Thank you.
                                  That problem can be caused by the ILI9341 controller from the TFT.
                                  If that is the case, the only solution is a replacement.
                                    Richard
                                    I use a SD 4mo FAT32
                                      Richard
                                      and also
                                      I tested with a 32mo
                                        I have a 32gig Class 10 sdhc formatted as fat32 MBT.
                                        How do I tell if I have the ILI9341?
                                          Calin @ajb2k3
                                          @ajb2k3 ILI9341 is the LCD driver used by the M5Stack TFT display: https://cdn-shop.adafruit.com/datasheets/ILI9341.pdf
                                            Ok, failed to get it to work with the jpgdraw script but if I convert to array it works, But!!!!!!
                                            I had to reduce the image to a 256bit Indexed image!
