    M5Paper EPD power consumption
    54 Posts 11 Posters 261.5k Views 6 Watching
      tatar-andrei
      Yes, it's pretty straight forward to power down the ESP32 completely and the power draw in that state is about 1.5 uA.
      I did play around more with power down states and I managed to get a light sleep mode with fast wakeup from touch at around ~9mA.
      I didn't get to play around with doze mode yet. I hope to get 1-2 mA when touch is in doze (gesture?) mode and ESP32 in deep sleep.
      C J 2 Replies Last reply Reply Quote 0
      • B Offline
        bricox
        Hello @tatar-andrei,
        I am also going to use a power supply to continue analyzing the consumption of the various components because IT consumes a lot.
        Can we turn it off with a mos then turn it on again?
        Will it be able to reset itself without the ESP32 sending it an initialization sequence?
        I will study this ...
        SYL
          careyer @tatar-andrei
          @tatar-andrei said in M5Paper EPD power consumption:
          1.5 uA.
          @tatar-andrei could ou please share how you managed to get down to 1.5 uA? Is the ESP32 still in deepsleep in this state and can be woken up via RTC/timer or is the unit completley turned off and needs some user-interaction in order to wake up?
          (I have no M5paper yet and want to find out if it is suitable for my project).
          I am highly interested in how much amperage is drawn in deepsleep with the RTC configured to wake the ESP32 up in regular intervals. Could you please test this? Thanks man!
            tatar-andrei
            could you please share how you managed to get down to 1.5 uA?
            Turn off the mosfet that powers the ESP32 (M5.disableMainPower(); - https://github.com/m5stack/M5EPD/blob/main/src/M5EPD.h#L49). In this mode everything but the external RTC (BM8563) is powered off.
            In order to wake up from this mode you either need to press the button on the side, or use the external RTC interrupt.
            The M5 lib contains a few functions that do exactly this (setup the external RTC to wakeup the board in a few seconds): https://github.com/m5stack/M5EPD/blob/main/src/M5EPD.cpp#L133
            • B Offline
              bricox
              With a supply of 4.2V, U(R35)=11mV, equivalent to 1.1µA for RTC and zener D11current.
              Equivalence names table
              There is inversion between Left and Right, why not having simply called the buttons Top and Bottom?
              SYL
              • B Offline
                bricox
                i also made a fisrst compact schema to facilitate understanding
                SYL
                • B Offline
                  bricox
                  If the repository is facing the wheel,
                  "code source" is true, "SCH-name" is false
                  SYL
                  • B Offline
                    bricox
                    I completed the schema with VUSB_IN, VSYS and OR fonction with D9,D12
                    SYL
                    • MattMM Offline
                      MattM
                      I just received my M5Paper and I can not get a 100% charge? The power consumption also seems high. I am only observing the battery level indicator relative to device use. Is there a problem with the firmware? Is the Wifi function draining the battery prematurely?
                      • B Offline
                        bricox
                        On mine, the maxi level indicator of charge is 86% corresponding to 4.18V
                        I measured USB current with the program "Factory test" and a serial USB device named "UT25".
                        The value is 131 mA, without interraction.
                        I also wrote personal comments about all GPIOs (in french, my native language):
                        All GPIOs are represented (except non-existent ones : 20, 24, 28, 29, 30, 31)
                        SYL
                          ricecake @tatar-andrei
                          @tatar-andrei
                          Hello!
                          I was wondering if you could provide some reference for how you got into doze mode/wake on touch? I've been trying for a few days now and for the life of me can't seem to make any meaningful progress.
                            tatar-andrei
                            You can check other GT9xx drivers like (http://read.pudn.com/downloads710/sourcecode/embedded/2849392/gt9xx.c__.htm).
                            I will need to play some more with it. I'll probably post here a link to my repo once I push the code.
                            • B Offline
                              bricox @bricox
                              If you want to measure RTC and zener D11 current, i indicate the PCB resistors positions
                              SYL
                              • B Offline
                                bricox @tatar-andrei
                                As I was saying five days ago,
                                "I measured USB current with the program "Factory test" and a serial USB device named "UT25".
                                The value is 131 mA, without interraction."
                                Since then, I have measured the current according to the different programs :
                                The cause of this excess consumption is IT8951.
                                An alternative to this component is the 74HC4094D, 8-stage shift-and-store bus register, used as IO extander.
                                A competitor with the same display consumes 65 mA, i measured to.
                                SYL
                                • B Offline
                                  Here is Shift Register schema, the brend is Nexperia.
                                  SYL
                                    fonix232
                                    @bricox nice work on mapping out the power management system! I've noticed some peculiarities with the charging PMIC (SLM6635, which does not seem to have any english documentation). Specifically, it does not seem to have a proper measuring system set up while charging. Once you connect it to USB power, the indicated battery voltage is actually the charging voltage of the battery, which can be 20-30% higher than the actual (resting) voltage of the battery. This is quite visible if you let the M5Paper with the FactoryTest firmware run out of battery, then connect it to power and head to the factory test screen - the battery indicator will be between 30-50%, and reported battery voltage will be around 3.7-3.8V (which is impossible on a device that was just completely discharged).
                                    The main problem with this is that the battery cutoff voltage for charging seems to be 4.2V - even though the battery is rated 4.35V officially. You can see this, again, on the Factory firmware, by leaving the unit to charge. Once it hits 4.2V stable, charging is cut to that voltage (and the M5Paper displays ~85% battery left). If you disconnect the charger and reconnect it, charging voltage jumps up to 4.35V, however after some time it stops charging (or switches to trickle charging? Not sure about the inner workings of SLM6635), battery voltage slowly drops to 4.2V, and keeps idling there, requiring another disconnect-reconnect to fully charge it again.
                                    I was wondering, since there seems to be some rudimentary control over power management, would it be possible to reset the charging circuit, or somehow fake the disconnect-connect cycle on it? Even if it's a software workaround, it would be nice to be able to properly charge to maximum capacity - and also it would allow to collect appropriate readings while charging.
                                    What I hope for is that the next M5Paper generation gets a better power management solution, even if it's more expensive. Proper PMIC control - especially in low-power applications where one would use an eink screen with an ESP32 for periodic updates - is incredibly important, and right now, by the looks of it, all we have is analog voltage readouts of VBAT, not even the charging/charging complete signals are hooked up (which are arguably important here as well).
                                    Another thing I thought about regarding power saving - would cutting the power to the EXT ports and the EPD display (via methods disableEPDPower() and disableEXTPower()) result in any savings?
                                    Uhm... Pardon my ignorance but according to my research the IT8591 is a full-blown EPD timing controller, not just a bus register. I don't see how the 74HC4094D would be an alternative (most definitely not a drop-in replacement).
                                      Hi guys
                                      As @fonix232 pointed out the charging / charging complete signals (NSTDBY / NCHRG) of the battery charger are not hooked up in M5Paper.
                                      So I was wondering, what other external indicator are you guys using to know that the battery has been fully charged? What I mean is how to tell the battery is full w/o running some code checking for the battery voltage every now and then.
                                        felmue @tatar-andrei
                                        ... and without any previous state (unless written to FLASH/SD)...
                                        you can also save data into M5Papers EEPROM (FM24C02 - 2K-bit(256x8)-EEPROM) during shutdown.
                                          @fonix232 said in M5Paper EPD power consumption:
                                          Hello @fonix232
                                          I also thought the charger is only set for 4.2V cutoff voltage due to the fact that the charger IC in the M5Paper schematics is marked as SLM6600. However the charger IC in my M5Paper actually is a SLM6635 which by default has a charging termination voltage of 4.35V according to its data sheet.
                                            fonix232 @felmue
                                            @felmue then how do you explain that charging voltage is 4.35V until the battery reaches 4.2V, when the charging voltage drops to 4.2V as well?
