    [Core2] UiFlow - BOTTOM2 support
    Features Wish List
    5
    16
    28.8k
    • OyczEO
      OyczE
      Hey,
      please let us know when we could see BOTTOM2 support in UiFlow.
      Regards
      Mati
      • ZontexZ
        Zontex
        There is support already, you can go to the hardware tab and get the RGB and IMU which are located on Bottom2 as well - they have the same pin map as Core2.
        • OyczEO
          OyczE
          Hey @Zontex you mean this ?
          if Yes this is not working on my core2 + bottom.
          • OyczEO
            OyczE
            also port mapping is a bit wrong
            maybe the old idea with add a a core as the unit would be better.
              Hello @Zontex
              for I2C you are correct, SDA/SCL (GPIOs 21/22) are identical on the Core2 Expansion board and M5GO2 so either IMU will work.
              However for RGB the original M5GO is using GPIO 15 whereas the newer M5GO2 uses GPIO 25 for RGB - so most likely it will not just work. (Or am I missing something?)
              • ZontexZ
                Zontex @felmue
                  Hello @Mati
                  I have received my M5GO2 bottom yesterday. @Zontex was correct, UIFlow support for M5GO2 is already in M5Core2 firmware 1.7.1. What is missing is enabling the 5 volts boost IC in M5Core2. W/o that the RGB LEDs do not have power. This works for me:
                  Cheers
                  • OyczEO
                    OyczE @felmue
                    @felmue said in [Core2] UiFlow - BOTTOM2 support:
                    Hello @Mati
                    Cheers
                    Great find ! big thx @felmue
                    Lets hope @Zontex will fix this. core2 section is missing https://docs.m5stack.com/#/en/uiflow/hardware?id=power-m5stack
                    • OyczEO
                      OyczE
                      Fun fact ... after a while when all was working my env2 or tvoc is unable to communicate ....
                        Hi @Mati
                        I am just wondering if the I2C failure could be a connectivity issue between M5Core2 and M5GO2? Maybe try to separate the two and then stack them again?
                        • OyczEO
                          OyczE
                          Well did it already on solo mode ic is dead as well...
                          • O
                            Ove
                            If you are using firmware version 1.7.1 then I suggest trying version 1.7.0 because in 1.7.1 the power to external devices are off when the device is powered on and even if you use the "Set bus power mode" block it is trying to initialize your "Units" before they get any power and this will cause problems like this.
                            It is possible to enable power before the Units are initialized if you switch to the python tab... but this should be fixed in a new firmware release.
                              Hi guys
                              @Mati : sorry to hear. Are you saying your M5Core2 with, lets say factory firmware installed, no longer is able to detect any internal I2C devices?
                              @Ove : you are correct, when I run below code in UIFlow 1.7.1 with firmware 1.7.1 on M5Core2 the attached unit (Ameter) is correctly found by the I2C scan
                              and returns a list with the two devices, e.g. [72, 81].
                              However that is only true as long as I do not define / add the Ameter unit. As soon as I add the Ameter unit I get an error that the Ameter is not found. So yes, it looks like some I2C initialisation is already taking place before the UIFlow code has a chance to run.
                              @Zontex : maybe it would make sense to allow setting the initial Bus Power Mode similar to the WiFi settings via M5Burner?
                              • OyczEO
                                OyczE @Ove
                                @ove said in [Core2] UiFlow - BOTTOM2 support:
                                yep rollback to 1.7.0 bring back the i2c. Thx @Ove
                                so we have a big issue inside 1.7.1 ...
                                  Hi guys
                                  UIFlow 1.7.1.1 for M5Core2 is out and it seems to fix the power issue on port A. I can now scan and use units on port A w/o the need to add the Set bus power mode 0 instruction.
                                  Happy Stacking!
                                  • C
                                    ctenophore
                                    Hello everyone,
                                    I just wanted to chime in and mention that with UIFlow firmware 1.7.1.1 that I also do not have the RGB leds showing up as hardware options in block view in the UIFlow IDE. I do not have the "Set bus power mode" as an available block. I CAN however call rgb.setColorAll() and other rgb functions from the python code and get the correct output from the LED strips on the Core2 M5go Bottom2 hardware. So I am not sure what that means as far as where the bug is.
                                    Thank you!
