Super simple RGB mixer
My first time working with this hardware and UIflow / uPython I made a super simple RGB mixer.
(ty felmue for teaching me how to format code)
from m5stack import from m5ui import from uiflow import setScreenColor(0x222222) varBarFactor = None varR = None varG = None varB = None varHexR = None varHexG = None varHexB = None lb_RGBval = M5TextBox(26, 8, RGB, lcd.FONT_UNICODE, 0xFFFFFF, rotate=90) rec_R = M5Rect(44, 240, 50, 0, 0xff0000, 0xff0000) rec_G = M5Rect(133, 240, 50, 0, 0x00ff00, 0x00ff00) rec_B = M5Rect(224, 240, 50, 0, 0x0000ff, 0x0000ff) def workR() global varBarFactor, varR, varG, varB, varHexR, varHexG, varHexB if btnA.isPressed() varR = varR + 1 if varR 255 varR = 0 rec_R.setSize(height=int((varR varBarFactor))) rec_R.setPosition(y=(240 - int((varR varBarFactor)))) varHexR = str(hex(varR))[2] if len(varHexR) 2 varHexR = (str('0') + str(varHexR)) def workG() global varBarFactor, varR, varG, varB, varHexR, varHexG, varHexB if btnB.isPressed() varG = varG + 1 if varG 255 varG = 0 rec_G.setSize(height=int((varG varBarFactor))) rec_G.setPosition(y=(240 - int((varG varBarFactor)))) varHexG = str(hex(varG))[2] if len(varHexG) 2 varHexG = (str('0') + str(varHexG)) def workB() global varBarFactor, varR, varG, varB, varHexR, varHexG, varHexB if btnC.isPressed() varB = varB + 1 if varB 255 varB = 0 rec_B.setSize(height=int((varB varBarFactor))) rec_B.setPosition(y=(240 - int((varB varBarFactor)))) varHexB = str(hex(varB))[2] if len(varHexB) 2 varHexB = (str('0') + str(varHexB)) lcd.setBrightness(10) varBarFactor = 0.95 varHexR = '00' varHexG = '00' varHexB = '00' varR = 0 varG = 0 varB = 0 while True workR() workG() workB() rgb.setColorAll((varR 16) (varG 8) varB) lb_RGBval.setText(str((str('RGB #') + str(((str(varHexR) + str(((str(varHexG) + str(varHexB)))))))))) wait_ms(2)
