    flash status
    Cores
    4.0k
    • T
      TT
      I use M5Stack Basic.
      Executing the command "esptool --port COM3 write_flash_status --non-volatile 0", I got the following result.
      I would like to know the meaning the code of "flash status" as 0xff42 or 0xff40.
      I could not find any document regarding it.
      Would you tell me the web site for the "flash status" information?
      esptool.py v2.6
      Serial port COM3
      Connecting....
      Detecting chip type... ESP32
      Chip is ESP32D0WDQ6 (revision 1)
      MAC: (mac address)
      Uploading stub...
      Running stub...
      Stub running...
      Initial flash status: 0xff42
      Setting flash status: 0x0000
      After flash status: 0xff40
      Hard resetting via RTS pin...
      Thanks in advance.
      • T
        TT
        I found the following documents.
        Command description
        https://github.com/espressif/esptool/wiki/Advanced-Commands#write_flash_status
        Source code
        https://github.com/espressif/esptool/blob/master/esptool.py
        L3499
        def write_flash_status(esp, args)
        GD25Q32C datasheet
        http://www.elm-tech.com/ja/products/spi-flash-memory/gd25q32/gd25q32.pdf
