    Core2 RTC
    Core 2
    6.9k
      sheepDog
      the library RTC control then BM8563. It is possible to get and set time and date.
      If I set the time, the display on the screen was correct, but the RTC stopped running.
      I used these lines to setup time and date:
          RTC_DateTypeDef RTC_DateStruct;
          RTC_DateStruct.WeekDay = 3;
          RTC_DateStruct.Month   = 9;
          RTC_DateStruct.Date    = 23;
          RTC_DateStruct.Year    = 2020;
          M5.Rtc.SetData(&RTC_DateStruct);
          RTC_TimeTypeDef RTC_TimeStruct;
          RTC_TimeStruct.Seconds = 0;
          RTC_TimeStruct.Minutes = 0;
          RTC_TimeStruct.Hours   = 12;
          M5.Rtc.SetTime(&RTC_TimeStruct);
      There is a stop bit at BM8563 but how can I set it correct with the M5Core2 RTC-library?
      V 1 Reply Last reply Reply Quote 0
      • V
        vgamlc @sheepDog
        I have the same problem, the time is right but the date is wrong. please a solution
          sirpenrose
          Try to replace
          with
          M5.Rtc.SetDate(&RTC_DateStruct);
          it worked for me.
