    Micropython - SHT30 in BTC Base
    Bases
    5
    7
    16.4k
    • K
      kedulowt
      If someone would try work with SHT30, I recommend:
      https://github.com/rsc1975/micropython-sht30
      but in this base you should propertly sel scl, sda pins and i2c addres SHT30 is 0x44.
      Code:
      from sht30 import SHT30
      sht30_sensor = SHT30(scl_pin=22, sda_pin=21, delta_temp=-3, i2c_address=0x44)
      temperature, humidity = sht30_sensor.measure()
      Also what i noticed that is showed temperature is higher than real. To correct it i use delta_temp.
      ajb2k3A 1 Reply Last reply Reply Quote 3
      • TitiMobyT
        TitiMoby
        It is a bit too early because MicroPython is still not there on M5Paper that I own, but as it uses the same SHT30, I also noticed some delta issue in temperature using Arduino.
        Is it a common thing with this component ?
          sj3fk3
          I honestly don't understand M5Stack's way of working. There is this ENV2 with python support: https://docs.m5stack.com/#/en/unit/envII it has a SHT30, but then you spend $80 on a M5Paper and you don't get python support for the SHT30. How hard is it to put in the the right lib.
          I know I can do it myself, but M5stack should have done this already :-/
            ajb2k3 @sj3fk3
            @sj3fk3 said in Micropython - SHT30 in BTC Base:
            Micropython on the M5Paper is in early alpha because we pushed M5Stack to get it out before the holiday. I spent yesterday doing some testing and I cannot get any SHT30 devices to work no matter if its the internal SHT30 on the paper or the env2 unit.
            What lib are you using as I cant even get raw reg read and writes to work.
              ajb2k3 @kedulowt
              @kedulowt said in Micropython - SHT30 in BTC Base:
              I can't get this to work
                File "sht30.py", line 40, in __init__
              NameError: name 'I2C' isn't defined
              • W
                Wolli01
                Vielleicht hilft euch das weiter. Läuft auf einem M5Stick-C
                main.py
                import unit
                import machine
                import array
                import sht31
                from machine import I2C, Pin
                i2c = I2C(freq=100000, scl=Pin(32), sda=Pin(33) )
                sensor = sht31.SHT31(i2c, addr=0x44)
                while True:
                #Sensor SHT31-----------------------------------------------------------
                temp_humi = sensor.get_temp_humi()
                wait_ms(600)
                Temperatur = round(temp_humi[0],2)
                Feuchte = round(temp_humi[1],2)
                sht31.py
                import time
                R_HIGH = const(1)
                R_MEDIUM = const(2)
                R_LOW = const(3)
                class SHT31(object):
                Diese Klasse implementiert eine Schnittstelle zur SHT31 Temperatur und Luftfeuchtigkeit.
                Sensor von Sensirion.
                # Diese statische Karte hilft, den Heap und die Programmlogik sauber zu halten.
                _map_cs_r = {
                True: {
                R_HIGH : b'\x2c\x06',
                R_MEDIUM : b'\x2c\x0d',
                R_LOW: b'\x2c\x10'
                False: {
                R_HIGH : b'\x24\x00',
                R_MEDIUM : b'\x24\x0b',
                R_LOW: b'\x24\x16'
                def __init__(self, i2c, addr=0x44):
                    Initialisiert ein Sensorobjekt auf dem angegebenen I2C-Bus, auf das von der
                    angegebene Adresse.
                    if i2c == None or i2c.__class__ != I2C:
                        raise ValueError('I2C-Objekt als Argument benötigt!')
                    self._i2c = i2c
                    self._addr = addr
                def _send(self, buf):
                    Sendet das angegebene Pufferobjekt über I2C an den Sensor.
                    self._i2c.writeto(self._addr, buf)
                def _recv(self, count):
                    Lesen von Bytes vom Sensor über I2C. Die Anzahl der Bytes kann angegeben werden.
                    als Argument.
                    Liefert ein Bytearray für das Ergebnis.
                    return self._i2c.readfrom(self._addr, count)
                def _raw_temp_humi(self, r=R_HIGH, cs=True):
                    Lesen Sie die Rohtemperatur und Luftfeuchtigkeit vom Sensor ab und überspringen Sie CRC. Überprüfung.
                    Liefert ein Tupel für beide Werte in dieser Reihenfolge.
                    if r not in (R_HIGH, R_MEDIUM, R_LOW):
                        raise ValueError('Falscher Wiederholbarkeitswert angegeben!')
                    self._send(self._map_cs_r[cs][r])
                    time.sleep_ms(50)
                    raw = self._recv(6)
                    return (raw[0] << 8) + raw[1], (raw[3] << 8) + raw[4]
                def get_temp_humi(self, resolution=R_HIGH, clock_stretch=True, celsius=True):
                    Lesen Sie die Temperatur in Grad Celsius oder Fahrenheit und relativ dazu ab.
                    Feuchtigkeit. Auflösung und Taktverlängerung können festgelegt werden.
                    t, h = self._raw_temp_humi(resolution, clock_stretch)
                    if celsius:
                        temp = -45 + (175 * (t / 65535.0))
                    else:
                        temp = -49 + (315 * (t / 65535.0))
                    return temp, 100 * (h / 65535.0)
                  sj3fk3 @ajb2k3
                  @ajb2k3 said in Micropython - SHT30 in BTC Base:
                  For now I have abandoned micro python and switched to (yuck) C and platformio.
