    Can't upload with esptool.py to M5Atom on macOS Big Sur
    4 Posts 2 Posters 6.1k Views 1 Watching
    • B Offline
      blackketter
      I'm having trouble with uploading to an M5Atom using esptool.py on macOS Big Sur 11.2.2 with the error:
      A fatal error occurred: Timed out waiting for packet header
      I've tried to use the Updater_FW20200422 (suggested in another thread), but get another error with that tool:
      Detecting M5Stack products.
      Find M5Stack products.
      Kernel driver deteched.
      Apply magic success.
      Fail to cast magic stage 2, please contact vendor.
      Waiting for device in DFU mode.....................%
      Otherwise the serial port works and I am able to use esptool.py to read_mac:
      dean@lucky13 razzle % esptool.py --port  /dev/cu.usbserial-7D52471593 read_mac
      esptool.py v3.0
      Serial port /dev/cu.usbserial-7D52471593
      Connecting....
      Detecting chip type... ESP32
      Features: WiFi, BT, Dual Core, 240MHz, Embedded Flash, VRef calibration in efuse, Coding Scheme None
      Crystal is 40MHz
      MAC: 50:02:91:92:3e:e8
      Uploading stub...
      Running stub...
      Stub running...
      Hard resetting via RTS pin...
      Any suggestions on how to proceed?
      • B Offline
        blackketter @blackketter
        Also, I updated the CP210x Macintosh OS VCP Driver to v6 and that didn't help.
          Hello Dean
          according to the description the M5Atom requires an FTDI driver.
          Note: I don't have a Big Sur installation, so I cannot tell if that will actually help.
          Cheers
          • B Offline
            Thanks for the suggestion, @felmue, but I figured out the problem!
            The default baud rate of 460800 is too fast for this device. If I specify --baud 115200 (in platformio.ini, that would be upload_speed = 115200) it works.
            Maybe this will be useful to someone else in the future.
