    2 Relay on PaHub
    7.0k
      mad23
      Hello everyone, I would like to switch the relay separately using PaHub 2 and can't get any further. Does anyone have an example here of using the PaHub with Relay?
        Hello @mad23
        Pa.Hub is an I2C extension hub so unless your relays use I2C (which I doubt) you cannot use a Pa.Hub to connect and switch two relays.
        Did you mean Pb.Hub?
          mad23
          @felmue said in 2 Relay on PaHub:
          Would the PbHub be used for this application?
            Hello @mad23
            I'd say so, yes, but I don't have a Pb.Hub so I cannot say for sure, sorry.
            @all: maybe somebody who owns a Pb.Hub can help out here?
              mad23
              Hello felmue, thank you for your answer.
              @All benefit I want 2 con this relay:
              https://docs.m5stack.com/#/en/unit/relay
              Does anyone have an idea?
                Hello @mad23
                have you considered using the 4 relay unit?
                  You should be able to run up to 5 relay units connected to the i/ohub (pbhub).
