    Lcd driver for M5Stack Core2
    29 Posts 4 Posters 100.1k Views 2 Watching
      Russ @Wolli01
      @wolli01 Here is the driver I've been working on https://github.com/russhughes/ili9342c_mpy
      W B 4 Replies Last reply Reply Quote 2
      • W Offline
        Wolli01 @Russ
        @russ Thank You!
        • W Offline
          Wolli01 @Russ
          @russ
          Many, many thanks!
          It works perfectly, you saved my project.
            Russ @Wolli01
            @wolli01 Excellent, glad it worked for you.
            • B Offline
              BricoMS @Russ
              • W Offline
                Wolli01
                @russ
                How can you include the internal SD card in your firmware? Do you have any ideas about this?
                I have not found anything yet.
                • W Offline
                  Wolli01
                  Found out now.
                  It must be installed before the display driver in any case.
                  #SD-Card
                  uos.mount(machine.SDCard(slot=3, sck=18, mosi=23, miso=38, cs=4,), '/sd')
                  print(uos.listdir('/sd'))
                  • W Offline
                    Wolli01
                    Leider kommen diese Fehlereldungen wenn ich was speichern will. Das lesen geht.
                    E (39687) sdmmc_cmd: sdmmc_read_sectors_dma: sdmmc_send_cmd returned 0x107
                    E (39697) sdmmc_cmd: sdmmc_write_sectors_dma: sdmmc_send_cmd returned 0x105
                    • W Offline
                      Wolli01
                      I load the SD driver after the LCD everything goes but the screen is not displayed.
                      If I load the SD driver before the screen, the SD does not work.
                      Something interferes then.
                        Russ
                        I was able to make concurrent display and sdcard work on the original M5Stacks https://github.com/russhughes/TinyBigBuckBunny but have not been able to make it work on the Core2's yet. I'm not sure why yet.
                          Russ
                          I was able to get simultaneous display and sdcard access working. The M5CORE2 firmware.bin has been updated. See the tbbunny.py example from https://github.com/russhughes/ili9342c_mpy/blob/main/examples/M5CORE2/tbbunny.py
                          W 2 Replies Last reply Reply Quote 1
                          • W Offline
                            Wolli01 @Russ
                            @russ
                            Thank you for your work.
                            It works now.
                            • W Offline
                              Wolli01 @Russ
                              @russ
                              Hello, is there any way to use the three touch buttons as well?
                                Russ
                                Yes, I’ll add an example working with the touchscreen later tonight.
                                • W Offline
                                  Wolli01 @Russ
                                  @russ
                                  Super!
                                  Thank you for doing this work.
                                    Russ @Wolli01
                                    @wolli01 Updated repo with two examples using the touchscreen. The buttons on the Core2 are actually part of the touchscreen that extend below the display from about Row 240 to 279.
                                    Button press example:
                                    https://github.com/russhughes/ili9342c_mpy/blob/main/examples/M5CORE2/buttons.py
                                    Very simple paint program:
                                    https://github.com/russhughes/ili9342c_mpy/blob/main/examples/M5CORE2/paint.py
                                    • W Offline
                                      Wolli01 @Russ
                                      @russ
                                      Thank you very much for your effort.
                                      What is this code for in the end?
                                      Is it mandatory to use it?
                                      finally:
                                          # shutdown
                                          spi.deinit()
                                        ajb2k3 @Wolli01
                                        @wolli01 said in Lcd driver for M5Stack Core2:
                                        @russ
                                        finally:
                                            # shutdown
                                            spi.deinit()
                                        The code de initialises the SPI bus so that that other functions can use the pins or the bus
                                        • W Offline
                                          Wolli01 @ajb2k3
                                          Thanks for the info.
                                          Where is the best place to put it in the code
                                            Russ @Wolli01
                                            @wolli01 At the very end of the program before it quits.
                                            W 2 Replies Last reply Reply Quote 0
