    LAN module problem
    Modules
    10
    16.5k
      meirmark
      The LAN W5500 demo program for Arduino is not working.
      Any solution ?
        Hello @meirmark
        sorry to hear about your troubles. Could you please provide some additional information about your setup?
        • Which M5Stack device are you using? M5Stack (Base, Gray, Fire) or M5Core2?
        • How are you powering your setup? Through USB or through the power connector of the LAN W5500 base?
        • What exactly isn't working? Is there a problem with compiling the code? Downloading the code? Running the code?
        • Any error message?
        • What is your development environment? Arduino IDE or VS Code / PlatformIO?
        • And lastly, could you post your code?
          meirmark
          I work with the Arduino IDE.
          The Error is: cannot declare variable 'server' to be of abstract type 'EthernetServer'
          I found a by-pass that solve the problem by changing the "cores/esp32/Server.h" file .
          it works but it makes a new problem for other programs that use WiFi.
          Is there a real solution ?
            Hello @meirmark
            hmm, that doesn't sound right. Which Ethernet library are you using?
            When I was testing Ethernet last I used the Ethernet2 library as suggested in the web server example:
            * Web Server
            * Need to install Ethernet2 arduino library
            * Please don`t install it by arduino library manange
            * If install, delete it
            * Ethernet2 file in M5stack lib examples -> modules -> W5500 -> Ethernet2.zip
            You'll find it here.
              meirmark
              According to Arduino site ,the new Ethernet lib can work with the W5500 chip so no need the Ethernet2 lib.
              Link: https://www.arduino.cc/en/Reference/Ethernet
              I tested also with the Ethernet2 lib from the ESP32 and it works.
              Thanks.
                Hello @meirmark
                good to know. Thank you for reporting back. I appreciate it.
                Happy Stacking!
                • F
                  fblais
                  This code is tested and work fine. 1 jan 2021
                  • projet SWID_M5 ( Switch ID pour M5Stack)
                        version 0.3
                  date debut : 1 aout 2020
                  MODIF : 2 aout 2020
                  modif : 16-18 dec 2020 modif ethernet2 serveur tester et fonctionnel
                  programmation: Francois Blais Montreal QC
                  capture de trame pour la decouverte de commutateur (lldp)
                  materiels
                  M5stack core 4meg prog 1.2 meg ram
                  ecran affichage avec un OLED integer au bibli m5stack (esp32) M5.LCD.println();
                  3 bouton
                  1 haut parleur
                  module battery
                  module lan_w5500 ethernet2.h rj45
                  bibliotheques
                  chemin de bibli shield w5500 lecture en mode raw C:\Users\fblai\Documents\Arduino\libraries\Ethernet\src\utility
                  problèmes constatés
                  1- bibliotherque doit etre celle fournie par m5stack dans la section module/w5500 sinon erreur manque var
                  2- pour utiliser le serveur test de m5stack dans la section module/w5500 il faut prendre ladresse 192.168.0.177 pour ce conformer a la plage disponible sur mon routeur
                  3- il faut serrer les trois modules car probleme de connection physique sinon led power clignote
                  4- il faut mettre dans le w5500.init(CS) qui est CS=26 au lieu de celui par defaut qui est 10
                  5- utilisation des socket a partir de lobjet w5500.execCmdSn(s,sock_open ou close ou recv )
                  utilisation de m5stack
                  bouton de power sur le coté
                  peser une fois sur le power pour le demarrer ou le reinitialier
                  peser 2 fois sur le power pour le fermer
                  bibli
                  #include <M5Stack.h>
                  //------------------- ethernet2 w5500 lan rj45
                  #include <SPI.h>
                  #include <Ethernet2.h>
                  #include <utility/w5500.h> // doit etre sous <Ethernet2.h>
                  #define SCK 18 // adaptation pour m5stack
                  #define MISO 19
                  #define MOSI 23
                  #define CS 26
                  // Enter a MAC address and IP address for your controller below.
                  // The IP address will be dependent on your local network: FB:AD:BE:EF:FE:FB 192.168.0.177
                  byte mac[] = {
                  0xFB, 0xAD, 0xBE, 0xEF, 0xFE, 0xFB
                  SOCKET s; // RAW mode
                  int rbuflen ;
                  byte trame[335];
                  int NBR = 0;
                  int position[12];
                  affichage
                  String LCD_data[7];
                  void presentation(String L1,String L2,String L3,String L4,String L5,String L6,String L7,String L8){
                  M5.Lcd.clear();
                  M5.Lcd.setCursor(70, 20, 4);
                  M5.Lcd.println(L1);
                  M5.Lcd.setCursor(70, 60, 4);
                  M5.Lcd.println(L2);
                  M5.Lcd.setCursor(70, 80, 4);
                  M5.Lcd.println(L3);
                  M5.Lcd.setCursor(70, 100, 4);
                  M5.Lcd.println(L4);
                  M5.Lcd.setCursor(70, 120, 4);
                  M5.Lcd.println(L5);
                  M5.Lcd.setCursor(70, 140, 4);
                  M5.Lcd.println(L6);
                  M5.Lcd.setCursor(70, 160, 4);
                  M5.Lcd.println(L7);
                  M5.Lcd.setCursor(70, 180, 4);
                  M5.Lcd.println(L8);
                  declaration de mes fonctions
                  bool si_lldp();
                  void lldp();
                  String decoupe( unsigned int local );
                  int trouve( const byte rech[] );
                  String decoupevlan( unsigned int local );
                  int* trouvetlv();
                  String decompte;
                  void matrame();
                  String x2i(String monhexa);
                  // =============== fonctionne au debut du script seulement one shot =======================================
                  void setup()
                  Serial.begin(115200);
                  M5.begin(true, false, true);
                  M5.Power.begin();
                  M5.Lcd.setTextFont(4);
                  M5.Lcd.setCursor(50, 100, 4);
                  // ============ initialise lecran oled ===================
                  presentation( "SWID-M5 v0.3 " , " " ,"Capteur Ethernet", "" ,"Trame LLDP " ," "," ","F.Blais MTL 2020" );
                  delay(5000);
                  // ============ initialise ethernet en mode raw brodcast ===================
                  SPI.begin(SCK, MISO, MOSI, -1);
                  w5500.init(CS);
                  w5500.writeSnMR(s, SnMR::MACRAW);
                  w5500.execCmdSn(s, Sock_OPEN);
                  // ==================== en boucle continue ==============================================================
                  void loop()
                  NBR++;
                  // ===================== info sur la switch =======================
                  Serial.println(decompte);
                  rbuflen = w5500.getRXReceivedSize(s);
                  if(rbuflen>0) {
                  if(rbuflen > sizeof(trame))
                  rbuflen = sizeof(trame);
                  w5500.recv_data_processing(s, trame, rbuflen);
                  w5500.execCmdSn(s, Sock_RECV);
                  decompte = " b:" + String(NBR) + " g:" + String(rbuflen) ;
                  if ( rbuflen > 0 ) {
                  if (si_lldp()) {
                  lldp();
                  presentation( "" , LCD_data[0],LCD_data[1] ,LCD_data[2] ,LCD_data[3] , LCD_data[4] ,LCD_data[5], LCD_data[6]);
                  delay(30000);
                  // ================================== mes fonctions ====================================
                  void lldp(){
                  int local=0;
                  String partie;
                  trouvetlv();
                  // description
                  partie = decoupe( position[5] ) ;
                  LCD_data[1] = partie.substring(1,14);
                  LCD_data[2] = partie.substring(15,partie.length() );
                  // equivalent Unit/port
                  LCD_data[4] = decoupe(position[4] ) ;
                  LCD_data[4].trim();
                  // equivalent 00-80-c2-01 signature de la ligne vlan pos:187 0x0bfc = 3068
                  byte vlan[]={0x00,0x80,0xc2,0x01};
                  local = trouve(vlan);
                  if ( local < 330 )
                  LCD_data[6] = "Vlan:" + decoupevlan(local) ;
                  else
                  LCD_data[6] = " pas Vlan" ;
                  bool si_lldp() {
                  if( trame[2] == 1 && trame[3] == 128 && trame[4] == 194 && trame[7] == 14 ) {
                  matrame();
                  return true;
                  else
                  return false;
                  void matrame()
                  for(int x = 0 ; x< 334 ; x++)
                  Serial.print(trame[x]); Serial.print(" ");
                  Serial.println("");
                  Serial.print(trame[x],HEX);
                  Serial.println("");
                  // EXTRAIT UN MORCEAU EN HEXA ET LE RENVOI EN STRING
                  String decoupe( unsigned int local ) {
                  unsigned int i;
                  int grandeur = trame[local+1] ;
                  String texte=" ";
                  for ( i = ( local + 2 ) ; i < (local + grandeur + 2) ; i++ )
                  texte += (char)trame[i] ;
                  return texte;
                  String decoupevlan( unsigned int local ) {
                  unsigned int i;
                  int grandeur = trame[local-1] ;
                  grandeur = grandeur - 4 ;
                  String texte ;
                  for ( i = (local+4) ; i< ( (local+4) + ( grandeur) ) ; i++ )
                  texte += String(trame[i],HEX);
                  texte = x2i(texte);
                  texte.trim();
                  return texte;
                  // RECHERCHE UN MORCEAU SPECIFIQUE DANS LA TRAME
                  int trouve(const byte rech[] ) {
                  unsigned int i = 0;
                  for ( i = 0 ; i < 330 ; i++ ) {
                  if (trame[i] == rech[0])
                  if( (trame[i+1] == rech[1]) and (trame[i+2] == rech[2]) and (trame[i+3] == rech[3]) )
                  return i;
                  return 0;
                  // trouve les deplacements
                  int* trouvetlv(){
                  int nbr;
                  int pos = 16; position[0]=0; position[1]=16;
                  for ( nbr = 2 ; nbr < 9 ; nbr++ ) {
                  position[nbr] =  ( (pos + 2) + trame[pos+1]   );
                  pos  = position[nbr];
                  return position ;
                  String print_ip(const byte a[], unsigned int offset, unsigned int length) {
                  String ip;
                  for (unsigned int i = offset; i < offset + length; i++) {
                  // if(i>offset) Serial.print('.');
                  // Serial.print(a[i], DEC);
                  if (i > offset) ip = ip + '.';
                  ip = ip + String (a[i]);
                  return ip;
                  String print_mac(const byte a[], unsigned int offset, unsigned int length) {
                  String Mac;
                  LCD_data[1] = "";
                  for (unsigned int i = offset; i < offset + length; ++i) {
                  if (i > offset) {
                    //  LCD_data[1] = LCD_data[1] + Mac + ':';
                    Mac = Mac + ':';
                  if (a[i] < 0x10) {
                    Mac = Mac + '0';
                    //    LCD_data[1] = LCD_data[1] + Mac + '0';
                  Mac = Mac + String (a[i], HEX);
                  LCD_data[1] = LCD_data[1] + Mac;
                  return Mac;
                  // converti hexa vers dec en type string
                  int x = 0; int nbr;
                  for(nbr=0 ; nbr < monhexa.length() ; nbr++) {
                  if (monhexa[nbr] >= '0' && monhexa[nbr] <= '9') {
                    x *= 16;
                    x += monhexa[nbr] - '0';
                  else if (monhexa[nbr] >= 'A' && monhexa[nbr] <= 'F') {
                    x *= 16;
                    x += (monhexa[nbr] - 'A') + 10;
                  else if (monhexa[nbr] >= 'a' && monhexa[nbr] <= 'f') {
                    x *= 16;
                    x += (monhexa[nbr] - 'a') + 10;
                  else break;
                  return String(x,DEC);
                  // ================= fin script =====================================================================================================
                  • F
                    fblais
                    This script is tested and work fine. 1 jan 2021
                          version 0.3
                    MODIF : 2 aout 2020
                    materiels
                    3 bouton
                    1 haut parleur
                    module battery
                    bibliotheques
                    problèmes constatés
                    bibli
                    #include <SPI.h>
                    #define MISO 19
                    #define MOSI 23
                    #define CS 26
                    byte mac[] = {
                    int rbuflen ;
                    byte trame[335];
                    int NBR = 0;
                    int position[12];
                    affichage
                    String LCD_data[7];
                    M5.Lcd.clear();
                    M5.Lcd.println(L1);
                    M5.Lcd.println(L2);
                    M5.Lcd.println(L3);
                    M5.Lcd.println(L4);
                    M5.Lcd.println(L5);
                    M5.Lcd.println(L6);
                    M5.Lcd.println(L7);
                    M5.Lcd.println(L8);
                    bool si_lldp();
                    void lldp();
                    int* trouvetlv();
                    String decompte;
                    void matrame();
                    void setup()
                    M5.Power.begin();
                    delay(5000);
                    w5500.init(CS);
                    void loop()
                    NBR++;
                    if(rbuflen>0) {
                    if (si_lldp()) {
                    lldp();
                    delay(30000);
                    void lldp(){
                    int local=0;
                    String partie;
                    trouvetlv();
                    // description
                    LCD_data[4].trim();
                    if ( local < 330 )
                    else
                    bool si_lldp() {
                    matrame();
                    return true;
                    else
                    return false;
                    void matrame()
                    Serial.println("");
                    Serial.println("");
                    unsigned int i;
                    String texte=" ";
                    return texte;
                    unsigned int i;
                    String texte ;
                    texte = x2i(texte);
                    texte.trim();
                    return texte;
                    unsigned int i = 0;
                    return i;
                    return 0;
                    int* trouvetlv(){
                    int nbr;
                    return position ;
                    String ip;
                    return ip;
                    String Mac;
                    LCD_data[1] = "";
                    if (i > offset) {
                      Mac = Mac + ':';
                    if (a[i] < 0x10) {
                      Mac = Mac + '0';
                    return Mac;
                    int x = 0; int nbr;
                      x *= 16;
                      x *= 16;
                      x *= 16;
                    else break;
                    • H
                      HappyUser @fblais
                      @fblais Thank for this code. I managed to get it running. But I am wondering how on earth I could create a webserver based on this code. Currently I am really in the blind? Thanks for your attention.
                      • H
                        HappyUser @meirmark
                        @meirmark is there already a real solution? The simple example of Webserver for W5500 as provided by M5Stack gives me the same compilation error using the latest Arduino IDE. Please people from M5Stack : please respond with a working webserver example program. Many thanks.
