    Units CO2/TVOC
    Units
    4.8k
    • P
      pierre.halleux
      I'm trying the Units CO2/TVOC M5Stack Sick C.
      I'm just copy/pasting the code from the demo https://docs.m5stack.com/#/en/unit/tvoc
      And
      eCO2 stays blocked = 400ppm
      TVOC stay bloced at 0
      H2 moving a bit around 13580
      Any idea ?
      Does not seems to work fine.... I have another device Neatmo measuring CO2. It says it's not 400 but almost 1300ppm
      COuld you help?
      thanks,
      • mauwiiM
        mauwii
        You need to find the right calibration (baseline) values for your unit, so only initialize it, but do not define a baseline, then you will see a difference. Also it should be clean air in the room, f.e. not smoking with closed windows for days.
        for debugging purpose output the current baseline values as well, I think you will see a big difference to the ones in the sample then.
          Serge
          hi,
          don't know why but if you set that line n°31 in comment, it seems to work
          "# tvoc0.set_iaq_baseline(35187, 35502)
          while True:
          you may try to use the sample loop that you find in UIflow_Unit TVOC.
          As you can see on the picture below, TOVC/eCO2 can be use in a classroom context and it works fine
          I initialized it outside the window and came inside after
