    Core2 how to know the current battery level
    15 Posts 7 Posters 39.8k Views 3 Watching
      Pensive @Carles B.
      I implemented and tested this last night; While the calculation in the m5core2 factory test is linear - the battery performance is not.
      alt text
      My little Core2 lasted for 5 hours and 40 minutes.
      At about 5 hours and 25 minutes it was showing 20% (my battery meter turns red at 20% :) ), but the last 20% dropped off in 15 minutes. You can see this shown in the graph above for Li-ion batteries (i dont really know how close that is to the real performance of these batteries.
      We can extrapolate that as being a total life of 1 hour and 15 minutes - based onthe last 20%
      Does anyone know of a better curve solution someone has already done?
      If not I know the solution:
      Leave it to run down, pinging out to sdcard its battery voltage, current draw (for information) and the time elapsed.
      Then we can build a graph - just like the one I linked to based on the specific battery in this device - a new, healthy battery at room temperature - using a fairly normal level of power consumption.
      Then I can build a lookup table to represent this in code for this device.
      We could also build tables at different consumptions/temperatures if we wish as this will all affect when the "last 20%" fade kicks in. Upshot would be it will be much more accurate than this basic linear calculation is - so I'm going to do this later.
        revta @Pensive
        @pensive
        Thank you for running that test! I thought that's how it worked but didnt have time to get around testing it. The idea I had was to integrate either the time on or approx consumption and store it using the "preferences" library. The library saves whatever to the non-volatile memory so you wouldnt need the SD card. There was a write up of the libaray on the forums here:
        https://community.m5stack.com/topic/1496/storing-settings-in-the-memory-of-the-core
        So the two ideas:
        1. track how long the device has been on, update a preference with the time, subtract time on from the 5 hours 40 mins to get time remaining. It wont always be accurate, but probably close enough for most uses.
        2. Calculate the current consumption based on screen/wifi/bluetooth/etc being on, integrate all that and compare to total mah of the battery. (This would have a lot of factors, but could probably get you closer if you figured all them out.)
        I think the first one is the "easiest", do you have any thoughts?
        jimwsmithJ 1 Reply Last reply Reply Quote 0
        • jimwsmithJ Offline
          jimwsmith @revta
          @revta Here is the data from a test I just ran with approx 70mA battery drain. As you can see the line is reasonably linear until the very end. My chart starts with the device on charge until fully charged (charging circuit switches off). Then I manually disconnect the charger
            jimwsmith
              Pensive @jimwsmith
              @jimwsmith said in Core2 how to know the current battery level:
              Great thank you! It's the super steep drop off at the end that is messing with everything as the algorithm in the example code just draws a straight line from 3.2v to 4.2v so up until the steep drop off it says you have almost 50% more battery than you actually have! at that dropoff point the voltage is about 3.65v - so the percentage calculation at that point in the graph will read 45%!!!
              I've observed the same phenomenon in reverse when charging - it looks like you are charging really quickly because you hit 45% really quickly then it takes forever to make it the rest of the way - no wonder - you're only 20% charged!
              the most accurate and lightweight solution would be a lookup table. It could mimick that curve exactly at every percentage point using only 100 float values - and a very simple function:
              byte returnBatteryLevel(float currentVoltage){}
              @jimwsmith would you be willing to share that spreadsheet with me so I can pull the voltages out? I'd be happy to commit this function back to the M5core2 master so we can all report (more) accurate percentages.
              @revta getting to a projected time left would be a step 2 in this process - the first being getting an accurate percentage left, the second projecting how quickly this will diminish based on knowlegde of the battery and the current draw. I think this part is getting much more complicated as it will be drastically affected by different battery capacities (Faces kit or the battery stack units etc.) as well as the current draw - this is not so much the case with Step 1 so step 1 would be much more universal function and I think will remain reasoably accurate across battery capacities.
              P jimwsmithJ 2 Replies Last reply Reply Quote 0
                Pensive @Pensive
                @pensive said in Core2 how to know the current battery level:
                Actually I could do it using a handful of float "keyframes" at key points and calculate an interpolated percentage on the fly. Which is better - less ram / sketch ram? Or less CPU ticks? I would normally just burn a full lookup table to free up clockticks but memory can be a valuable resource too....
                100 * 4 bytes = 400 bytes + headers of sketch ram for the full lookup table.
                I could probably reduce this to 100 bytes but at a realtime processing cost (which will cost battery!). I'm leaning on the full lookup table idea.
                  Pensive
                  Sorry for multipost but I could also store the values in byte values with the first byte for the unit and second byte for the decimal would probably retain accuracy across all 100 values but store it all in 200 bytes. Simple bit of code for each query.....more clockticks though, I dont want to underestimate the parasitic load of constnatly performaing unnecessary calculations.....
                  Ahh: found this: https://en.wikipedia.org/wiki/Half-precision_floating-point_format
                  But not supported by arduino which is freaking wierd. floating point iwth half the memory usage? Yes please.....
                  But since its not supported a full lookup table is neater. others can save ram if they like but im not too bothered. This board has oodles of it.
                    jimwsmith @Pensive
                    @pensive Here is a link to the battery log code (it was done in Blocky for a workshop demo) and the log text file https://tinyurl.com/CtrlWrldExamplesView
                      Pensive @jimwsmith
                      Thank you :D
                      Will update here once it's implemented and pushed
                        favnec5
                        @wa-berlin said in Core2 how to know the current battery level:
                        batPercentage = ( batVoltage < 3.2 ) ? 0 : ( batVoltage - 3.2 ) * 100;
                        micropython welcome :
                        batPercentage=0 if batVoltage<0 else round((batVoltage-3.2)*100)
                        lcd.print(str(batPercentage)+"%",0,0)
                        Thomas
