    (Solved)M5StickC+ToF:I2C bus error (19)
    4 Posts 2 Posters 6.4k Views 1 Watching
      Koms
      While using the M5StickC with the M5STACK-TOF-UNIT "Dostance Sensor" connected I receive the following error when running the simple block code on UIFlow
      It used to work fine(using same code), but suddenly I receive the error.
      Error:
      I2C bus error (19)
      Code(from UIFlow)
      from m5stack import *
      from m5ui import *
      from uiflow import *
      import time
      import unit
      setScreenColor(0x111111)
      tof0 = unit.get(unit.TOF, unit.PORTA)
      label0 = M5TextBox(8, 27, "Text", lcd.FONT_Default, 0xFFFFFF, rotate=0)
      while True:
        label0.setText(str(tof0.distance))
        wait(1)
        wait_ms(2)
      I try another code also, but I still recieved same error.
      it looks like
      part might has a probelm.
      from m5ui import *
      import time
      import unit
      while True:
        label0.setText(str('Hello M5'))
        wait(1)
        wait_ms(2)
      Any suggestions would be appreciated.
      • felmueF Online
        Hello @Koms
        I am running your code just fine with UIFlow firmware 1.7.3 on my M5StickC.
        • are you using the latest UIFlow firmware?
        • have you tried another cable? (I get error 19 when I disconnect the unit)
        • is the cable plugged in all the way?
          Koms
          Hi! @felmue
          Thank you for your advices.
          Yes
          I tried another cable, the problem is solved!
          Thank you so much!
          • felmueF Online
            Hello @Koms
            you are welcome. Thank you for reporting back. I am glad to hear you got it working.
            Cheers
