    Graphic functions not working
    2 Posts 2 Posters 4.2k Views
      flyceo
      Hi there,
      I am new to M5Stack but already programmed some stuff for esp8266 using platformio.
      I loaded all the necessary libs and board definitions and tried a short script:
      #include <M5Core2.h>
      void setup(){
        // Initialize the M5Stack object
        // LCD display
        M5.Lcd.print("Hello world!");
      // the loop routine runs over and over again forever
          M5.update();
      Everything worked as expected.
      But then I added some Code like this:
      M5.Lcd.fillRect(10, 10, 100, 100, TFT_YELLOW);
      or this:
      M5.Lcd.fillScreen(TFT_RED);
      and suddenly the screen stay black. You can only see the backlight working. When I remove the fill... rod draw.... part, it works again. What am I doing wrong?
      Thanks,
      Roland
        Hello @flyceo
        not sure what's going on on your side as your code runs and works fine here - using PlatformIO as well. I see the text and the yellow square just fine.
        What does your platform.ini look like?
