    ATOM HUB AC/DC, RS-485 VOLTAGE CONVERTER, VOLTAGE PROBLEM
    Atom
    5.1k
    • K
      kine90
      I am working on a project where the switch is controlled by the M5 PIR SENSOR.
      When I power the ATOM from USB everything works fine, when I power it with a 12V 3A PSU thought the RS485 voltage converter the PIR begins malfunctioning (fake triggers).
      I checked the voltage of the two groove outputs (from the hub and from the atom lite) under USB and 12V power. As long as USB is connected, the interfaces shows a quite stable 4.98V.
      When the USB is unplugged, leaving only the 12V power source, the voltage drops to 3.3-3.28V, if the atom is removed it goes back to 5V
      I guess this is causing the PIR to misbehave, since it requires 5V.
      What´s wrong?
      According to labels on the components and to the HUB schematics, I expect 5V 2A from the DC/DC converter.
      • J
        JasonTay
        Hi it seem you are powering the 12v wrongly.
        Based on sticker of the HUB, red is 12v and black is gnd.
        Hope this helps
        Jason
          ajb2k3 @kine90
          @kine90 said in ATOM HUB AC/DC, RS-485 VOLTAGE CONVERTER, VOLTAGE PROBLEM:
          What´s wrong?
          Based on your photo's you haven't connected the 12V to the correct pins of the RS485 connection.
          12V needs to be connected to the RS485's red and black pins.
