    WiFi can't connect on 2017.6 basic core (works on Fire)
    2 Posts 2 Posters 4.6k Views
      anichang
      Very minimal sketch:
        M5.begin(true,true,true,true);
        M5.Power.begin();
        WiFi.begin(ssid, password);
        M5.Lcd.println("TODO");
        delay(500);
        M5.update();
        delay(1000);
      Doesn't work on my old Core:
      18:35:52.956 -> rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
      18:35:52.956 -> configsip: 0, SPIWP:0xee
      18:35:52.956 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
      18:35:52.956 -> mode:DIO, clock div:1
      18:35:52.956 -> load:0x3fff0018,len:4
      18:35:52.956 -> load:0x3fff001c,len:1216
      18:35:52.956 -> ho 0 tail 12 room 4
      18:35:52.956 -> load:0x40078000,len:10944
      18:35:52.956 -> load:0x40080400,len:6388
      18:35:52.956 -> entry 0x400806b4
      18:35:53.287 -> M5Stack initializing...OK
      18:35:53.751 -> [D][WiFiGeneric.cpp:374] _eventCallback(): Event: 0 - WIFI_READY
      18:35:53.751 -> [D][WiFiGeneric.cpp:374] _eventCallback(): Event: 2 - STA_START
      18:35:57.790 -> [D][WiFiGeneric.cpp:374] _eventCallback(): Event: 5 - STA_DISCONNECTED
      18:35:57.790 -> [W][WiFiGeneric.cpp:391] _eventCallback(): Reason: 2 - AUTH_EXPIRE
      18:36:01.862 -> [D][WiFiGeneric.cpp:374] _eventCallback(): Event: 5 - STA_DISCONNECTED
      18:36:01.862 -> [W][WiFiGeneric.cpp:391] _eventCallback(): Reason: 2 - AUTH_EXPIRE
      18:36:05.901 -> [D][WiFiGeneric.cpp:374] _eventCallback(): Event: 5 - STA_DISCONNECTED
      18:36:05.901 -> [W][WiFiGeneric.cpp:391] _eventCallback(): Reason: 2 - AUTH_EXPIRE
      18:36:09.941 -> [D][WiFiGeneric.cpp:374] _eventCallback(): Event: 5 - STA_DISCONNECTED
      18:36:09.941 -> [W][WiFiGeneric.cpp:391] _eventCallback(): Reason: 2 - AUTH_EXPIRE
      18:36:14.014 -> [D][WiFiGeneric.cpp:374] _eventCallback(): Event: 5 - STA_DISCONNECTED
      18:36:14.014 -> [W][WiFiGeneric.cpp:391] _eventCallback(): Reason: 2 - AUTH_EXPIRE
      18:36:18.053 -> [D][WiFiGeneric.cpp:374] _eventCallback(): Event: 5 - STA_DISCONNECTED
      18:36:18.053 -> [W][WiFiGeneric.cpp:391] _eventCallback(): Reason: 2 - AUTH_EXPIRE
      18:36:22.091 -> [D][WiFiGeneric.cpp:374] _eventCallback(): Event: 5 - STA_DISCONNECTED
      18:36:22.091 -> [W][WiFiGeneric.cpp:391] _eventCallback(): Reason: 2 - AUTH_EXPIRE
      It works on Fire:
      18:40:11.811 -> rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
      18:40:11.811 -> configsip: 0, SPIWP:0xee
      18:40:11.811 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
      18:40:11.811 -> mode:DIO, clock div:1
      18:40:11.811 -> load:0x3fff0018,len:4
      18:40:11.811 -> load:0x3fff001c,len:1216
      18:40:11.811 -> ho 0 tail 12 room 4
      18:40:11.811 -> load:0x40078000,len:10944
      18:40:11.811 -> load:0x40080400,len:6388
      18:40:11.811 -> entry 0x400806b4
      18:40:12.142 -> M5Stack initializing...[W][sd_diskio.cpp:169] sdCommand(): no token received
      18:40:12.241 -> [W][sd_diskio.cpp:169] sdCommand(): no token received
      18:40:12.341 -> [W][sd_diskio.cpp:169] sdCommand(): no token received
      18:40:12.473 -> [E][sd_diskio.cpp:194] sdCommand(): Card Failed! cmd: 0x00
      18:40:12.473 -> [W][sd_diskio.cpp:505] ff_sd_initialize(): GO_IDLE_STATE failed
      18:40:12.473 -> [E][sd_diskio.cpp:775] sdcard_mount(): f_mount failed: (3) The physical drive cannot work
      18:40:12.473 -> [W][sd_diskio.cpp:169] sdCommand(): no token received
      18:40:12.539 -> [W][sd_diskio.cpp:169] sdCommand(): no token received
      18:40:12.638 -> [W][sd_diskio.cpp:169] sdCommand(): no token received
      18:40:12.738 -> [E][sd_diskio.cpp:194] sdCommand(): Card Failed! cmd: 0x00
      18:40:13.069 -> OK
      18:40:13.201 -> [D][WiFiGeneric.cpp:374] _eventCallback(): Event: 0 - WIFI_READY
      18:40:13.201 -> [D][WiFiGeneric.cpp:374] _eventCallback(): Event: 2 - STA_START
      18:40:15.353 -> [D][WiFiGeneric.cpp:374] _eventCallback(): Event: 4 - STA_CONNECTED
      18:40:15.386 -> [D][WiFiGeneric.cpp:374] _eventCallback(): Event: 7 - STA_GOT_IP
      18:40:15.386 -> [D][WiFiGeneric.cpp:419] _eventCallback(): STA IP: 192.168.1.161, MASK: 255.255.255.0, GW: 192.168.1.254
      Any clue?
      • ZontexZ Offline
        Zontex
        Could you please include the imports at the beginning of the code? did you import the proper library?
        it seems that it says the SDCard failed, could you run the factory test image on your old core to see if you get any issues?
