    Get NTP timestamp with COM.LTE module does not work?
    UIFlow
    3.6k
    • T
      teiafra
      using a M5S Core1 with COM.LTE for mobile data connectivity which an MQTT client, implemented with UIFlow, uses pretty well to send data. Now I need to get a timestamp to be put into MQTT flow.
      I thought to use NTP blocks library but apparently it does not work when underlying connection is mobile while it works only with WiFi.
      Any tip to overcome such a limitation?
