    White screen when using LoRa module
    FAQS
    9.9k
    • K
      kieran.osborne
      Hello everyone, when I try to use the LoRa module i'm just getting a completely white screen.
      The code i'm using is:
      #include <M5Stack.h>
      #include <M5LoRa.h>
      // override the default CS, reset, and IRQ pins (optional)
      LoRa.setPins(); // default set CS, reset, IRQ pin
      Serial.println("LoRa Receiver");
      M5.Lcd.println("LoRa Receiver");
      // frequency in Hz (433E6, 866E6, 915E6)
      if (!LoRa.begin(433E6)) {
      Serial.println("Starting LoRa failed!");
      M5.Lcd.println("Starting LoRa failed!");
      while (1);
      // LoRa.setSyncWord(0x69);
      Serial.println("LoRa init succeeded.");
      M5.Lcd.println("LoRa init succeeded.");
      // try to parse packet
      int packetSize = LoRa.parsePacket();
      if (packetSize) {
      // received a packet
      Serial.print("Received packet: "");
      M5.Lcd.print("Received packet: "");
      // read packet
      while (LoRa.available()) {
        char ch = (char)LoRa.read();
        Serial.print(ch);
        M5.Lcd.print(ch);
      // print RSSI of packet
      Serial.print("\" with RSSI ");
      Serial.println(LoRa.packetRssi());
      M5.Lcd.print("\" with RSSI ");
      M5.Lcd.println(LoRa.packetRssi());
      not sure how to add a code tag sorry.
      I have tried swapping the LoRa RST and INT pins according to someone on the forum to make the LoRa work, the LoRa seems to be working okay but the screen is just completely white.
      • L
        lelehel
        Hi!
        Same Situation here. If LoRa module connected, white screen. Faulty module?
        Lehel
        • L
          lelehel
          Ahhh I got it!
          https://www.aliexpress.com/item/M5Stack-Official-Stock-Offer-LoRa-Module-for-ESP32-DIY-Development-Kit-Wireless-433MHz-Built-in-Antenna/32848258447.html
          Pay Attention:
          To aviod the problem that the screen can not display, GPIO5, as the NSS pin of the LoRa module, needs to be pulled up when the system is initialized.
          pinMode(5,OUTPUT);
          digitalWrite(5,HIGH);
          m5.begin():
          Now it's working. ;)
          L.
          • RopR
            Rop
            Strange that this never affected me. But I've added a note to the LoRa section of my big post about all these boards.
