    UIFlow 1.7.5
    11 Posts 6 Posters 24.3k Views 4 Watching
    • m5stackM Online
      Ver 1.7.5 time : 2021.04.16
      v1.7.5
      new features
      • IoT Cloud support:
      • Azure IoT SAS token generated by the device.
      • machine: * CAN support(Experimental stage).
      • COM.X * COM.LoRaWAN support.
      • M5MQTT: * Support wildcard #&+(Experimental stage)
      Bug fix:
      • Core2 APP list bug fix.
      • Others bug fixed
        moe1979
        Could we expect in near time uiflow support for the 4Relay Unit, this would be reallly great
        m5stackM 1 Reply Last reply Reply Quote 2
          anvalin
          1.7.5 is supporting only COM.X LoraWan 470 and 915 modules but not the 868 MHz version M031-C?
          IAMLIUBOI 1 Reply Last reply Reply Quote 2
          • m5stackM Online
            m5stack @moe1979
            @moe1979 we will push it and speed up its progress. thank you feedback
            • IAMLIUBOI Offline
              IAMLIUBO @anvalin
              Hi @anvalin ,
              Sorry about that, since the M031-C module firmware version is relatively low, some AT commands do not match the AT user manual, so they are not supported yet.
              A 1 Reply Last reply Reply Quote 2
                mifi @m5stack
                @m5stack
                See next program example (UIFlow ver. 1.7.5), I guees something is wrong:
                and result is:
                  anvalin @IAMLIUBO
                  @iamliubo Thanks for the info. I wonder about wether it's going to be possible to upgrade firmware of said LoraWAN module M031-C. How can this be done?
                    @IAMLIUBO is the Watch dog timer a system WDT or a Task WDT?
                    • IAMLIUBOI Offline
                      IAMLIUBO @ajb2k3
                      @ajb2k3 system WDT.
                      • IAMLIUBOI Offline
                        IAMLIUBO @anvalin
                        @anvalin It's possible.But I did't test, I will let you know,if I test it.
                          ajb2k3 @IAMLIUBO
                          @iamliubo Thank you.
