    Powering Atom Lite with 5V pins
    Atom
    6
    6
    14.6k
    • P
      pacaj2am
      Re: Can the Atom accept external regulated 5V power?
      I tried to power the Atom Lite modules from 5V groove pin and failed miserably (if I connect same power supply to USB-C connector - everything works.
      Is there more detailed schematics how is the powerline connected?
      Atom lite schema
      On this schema only 0.5A fuse is shown, but I have nothing else connected, so I shouldn't trigger that.
        ajb2k3 @pacaj2am
        @pacaj2am You can power the Atom via the 5V in pin on the back of the atom.
        • R
          robalstona
          I connect a Li-po battery (3.7V) directly to bottom pins GND, 5V and atom lite works. But usb2uart and neopixel led may not work or works incorrectly depends of battery voltage. In my case i need only esp32 to works.
          • D
            Dario
            I have too experimented powering both Atom Lite and the Atom Matrix via the groove connector or via the headers pins and I noticed a weird thing. If the voltage is a little below 5V, for example 4.6 or 4.7 Volts it works fine. If the voltage is a little above 5V, for example 5.2V it power up but it never connect to internet.
              Hello guys
              from the schematic there should be no difference whether you power M5Atom via 5V on the Groove connector or the 5 V pin in the back. Measuring for continuity between Groove and the respective pins in the back also shows they are connected 1:1 and are the same.
              Running a simple sketch on my M5Atom Matrix, which only connects WiFi and is showing that by changing the LEDs from red to green, I see that working ok with voltages from 2.8 V to 5.2 V.
              BTW: I am getting the same results with an M5Atom Lite.
              • GallowglassG
                Gallowglass
                To run devices like this from an external supply I'd recommend a little Buck regulator board such as the one Youmile does (https://www.amazon.co.uk/dp/B07TTH6C3J). You can then set the output to fixed 5V and drive the input from anything - USB 5V from a breadboard, a 9V PP3, 12V or 24V car, truck or boat battery etc. - with no worries about blowing anything in the Atom.
