šŸ¤–Have you ever tried Chat.M5Stack.com before asking??šŸ˜Ž
    M5StickC - M5.LCD draws only a part of the display
    arduino
    4 Posts 2 Posters 9.4k Views 1 Watching
    • L Offline
      lunard
      Hello to all, I have a big problem.
      I’m not able to draw the the whole display on my M5Stick C.
      Every calls to the M5.LCD object draws just an area of the display.
      Seems to be a ā€œscaleā€ problem, but I never seen such issue.
      In the attached image, the white box is the area I’m able to draw
      Someone has a similar problem
      Sadly the M5Stack support doesn’t answers to may email
      0_1619683766931_0124C680-E8C5-46E4-B46C-5C6F166C04CB.jpeg ![0_1619683705856_70F9B1AE-F818-46E6-AD25-30B0F8334AC9.jpeg](Uploading 71%)
        robalstona
        Its seems M5stickC Plus which have screen with greater resolution that M5StickC. Maybe you need or update a new m5stick libraries to use with bigger screen. Ewentually look into source files of library and find const/vars with screen resolution, maybe they are hardcoded.
        • L Offline
          lunard
          I will try today!! Thanks a lot
          • L Offline
            lunard
            There is aM5StickPlus library !! Thanks a lot!
            With your input, this post could be even better šŸ’—
