    Bluetooth in UI Flow
    Scheduled Pinned Locked Moved Features Wish List
    6 Posts 4 Posters 15.0k Views 3 Watching
    • ExieE Offline
      Exie
      Hi Folks,
      I'm new here, just picked up my first device, an M5 Atom Matrix.
      I've spent a day watching videos about UI Flow which is a really neat way to get started. The only notable omission is - no Bluetooth!
      It lists BLE as a feature on the box and it is supported by the processor, but just not exposed in UI Flow.
      This is sad as its a big step from using M5 Burner and UI Flow to get started so easily to now compiling MicroPython and bundling packages into it that I can push down onto the device manually. I really hope I don't end up going to C with PlatformIO to use the device.
      Even if Bluetooth wasn't exposed in UI Flow, but the python bluetooth module was installed in the UIFlow_Matrix image (currently 1.7.6)
      • OyczEO Offline
        OyczE
        hmm there is BLE in advance:
        • B Offline
          Bhagyashri7M
          I've spent a day watching videos about UI Flow which is a really neat way to get started. The only notable omission is - no Bluetooth! It lists BLE .
          and Don't forget to visit me back
          SevenMentor we have kept the Java classes in Nagpur flexible. From online classroom to fast-track & one-on-one classroom Java training is offered during weekdays and also on the weekends to the students.
          • B Offline
            benalb @OyczE
            @mati It seems it's not available for Sticks and Atoms.
            • ExieE Offline
              Exie
              On the box is says BLE ...
              alt text
              Just not implemented in the UI
              • ExieE Offline
                Exie
                By way of extension, the bluetooth statck doesnt seem to be in the UI Flow 1.7.6 image for the Atom Matrix:
                configsip: 188777542, SPIWP:0xee
                mode:DIO, clock div:1
                load:0x3fff0018,len:4
                load:0x3fff001c,len:5280
                ho 0 tail 12 room 4
                load:0x40078000,len:12908
                load:0x40080400,len:3512
                entry 0x4008063c
                       _  __ _
                 _   _(_)/ _| | _____      __
                | | | | | |_| |/ _ \ \ /\ / /
                | |_| | |  _| | (_) \ V  V /
                 \__,_|_|_| |_|\___/ \_/\_/
                APIKEY: <hidden>
                  File "_flow.py", line 44, in <module>
                KeyboardInterrupt:
                MicroPython a431828aa-dirty on 2021-04-29; M5Stack with ESP32
                >>> help("modules")
                IoTcloud/AWS      hardware/__init__ ucollections      units/_ir
                IoTcloud/Ali      hardware/button   ucryptolib        units/_joystick
                IoTcloud/Azure    hmac              uctypes           units/_laserrx
                IoTcloud/Tencent  i2c_bus           uerrno            units/_lasertx
                IoTcloud/__init__ inisetup          uhashlib          units/_light
                IoTcloud/blynk    libs/__init__     uhashlib          units/_makey
                MediaTrans/TimerCam                 libs/bmm150       uheapq            units/_mlx90640
                MediaTrans/__init__                 libs/bmp280       uiflow            units/_ncir
                MicroWebSrv/__init__                libs/config       uio               units/_op
                MicroWebSrv/microWebSocket          libs/dht12        ujson             units/_pahub
                MicroWebSrv/microWebSrv             libs/easyIO       umqtt/__init__    units/_pbhub
                MicroWebSrv/microWebTemplate        libs/echo         umqtt/robust      units/_pir
                ThirdParty/myCobot/myCobot          libs/emoji        umqtt/simple      units/_relay
                ThirdParty/myCobot/myCobotPro       libs/imu          unit              units/_relay4
                __main__          libs/m5mqtt       unitcam           units/_rfid
                _boot             libs/micropyGPS   units/VFunction/__init__            units/_rgb
                _flow             libs/mpu6050      units/VFunction/_apriltag_code      units/_rgb_multi
                _onewire          libs/mstate       units/VFunction/_bar_code           units/_servo
                _thread           libs/numbers      units/VFunction/_color_track        units/_tof
                _uasyncio         libs/nvs          units/VFunction/_dm_code            units/_tracker
                _webrepl          libs/pca9685      units/VFunction/_face_detect        units/_tvoc
                apa106            libs/pid          units/VFunction/_jpeg_transfer      units/_uhf_rfid
                base/GPS          libs/servo        units/VFunction/_line_tracker       units/_ultrasonic
                base/HDriver      libs/sh200q       units/VFunction/_motion             units/_unitcam
                base/Motion       libs/speak        units/VFunction/_qr_code            units/_uwb
                base/QRCode       libs/timeSchedule units/VFunction/_tag_reader         units/_v_function
                base/Stepmotor    libs/time_ex      units/VFunction/_target_track       units/_vibrator
                base/__init__     libs/urequests    units/_accel      units/_vmeter
                base64            libs/vl53l0x      units/_acsocket   units/_watering
                btree             m5stack           units/_adc        units/_weight
                builtins          m5uart            units/_ameter     uos
                cmath             m5ui              units/_angle      urandom
                collections/__init__                machine           units/_atom_motion                  ure
                collections/defaultdict             math              units/_bps        urllib/parse
                collections/deque max30100          units/_button     urllib/urequest
                comx/lte          menu/__init__     units/_cardKB     uselect
                deviceCfg         menu/cloud        units/_color      usocket
                display           menu/wifi         units/_dac        ussl
                esp               micropython       units/_dds        ustruct
                esp32             modules/_grbl     units/_dual_button                  utils
                espnow            modules/_lorawan_network            units/_earth      utime
                flashbdev         modules/_servo2   units/_env        utimeq
                flow/__init__     neopixel          units/_env2       uwebsocket
                flow/adaptation   network           units/_ext_io     uzlib
                flow/flowDeinit   ntptime           units/_fan        warnings
                flow/m5cloud      ntptime           units/_finger     wav/chunk
                flow/m5ucloud     simpleOTA         units/_gps        wav/wav_player
                flow/protocol     sys               units/_hall       wav/wave
                framebuf          uarray            units/_heart      wifiCfg
                gc                ubinascii         units/_imu6886    wifiWebCfg
                Plus any modules on the filesystem
